Windows 7: Windows 7 IDT Audio 5.1 Sound Problem.
20 Feb 2010   #1
Windows 7 PRO x64
Hi guys . 1 day ago i had a problem with my IDT audio on windows 7 . I couldn't set 5.1 option in the IDT Control Panel the setting jumped back to Stero options. I changed windows , changed alot of stuffs. I tried another way posted here that said to set 5.1 in windows control panel , this soultion was odd because in winamp was 5.1 but was a bad bad sound , no bass and with echo. I have to mention that in windows TEST all speakers sounds good , but music/video/apps/game.. ... This morning i found the best solution for everyone who's been in the situation. I found some drivers, that they rlly work , and you can change to 5.1 in IDT control Panel. I tested the drivers on Windows 7 Ultimate x32&x64 and i'm curently using them in Windows 7 Pro x64. I hope that everyone who had this problem, this driver will resolve . Cheers.
PS: My audio was IDT on a dp35dp Intel mboard
Drivers here :
MEGAUPLOAD - The leading online storage and file delivery service
10 May 2010   #2
Google Traduction
Thanks: D
It's not perfect but it works better than others.
29 May 2010   #3
Windows 7 PRO x64
Well,if you or anyone alse can find a better one,i would be glad to install :P
30 May 2010   #4
windows Seven 7100
Is this the same driver for the DELL Studio Laptops?
13 Feb 2011   #5
Windows 7 Professional 64-bit
Sigmatel STAC9271D on-board audio AC97 IDT driver
Thank you cristi2k!
This worked like a champ on my Intel Desktop Board DG965WH and Logitech 5.1 surround sound set. I downloaded it from your link at MEGAUPLOAD too.
13 Feb 2011   #6
Windows 7/10 64 bit
I have an Intel DP35DP motherboard. I'm not using the SigmaTel (now called IDT) sound as I have a separate sound card installed. But the IDT drivers on the Intel site for this motherboard worked for me when I did use them.
Search this Thread:
Advanced Search
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
Audio problem in W7 (no sound)
Hello, Two hours ago I plugged a sound wire from the PC to my LCD TV. And after I unplagged it I had some problems in my PC, I dont know why.. so I restarted. After the restart I had an icon of a speaker with a red "X" next to it.. It sais " Audio output device is not installed" I dont know...
SB Audigy 2 ZS Audio sound problem
i just installed win7 and i love it but sound sucks, i have SB Audigy 2 ZS Audio sound card, and i installed driver for it but my sound still sucks my problem is that i cant turn of 3D sound, i have stereo sennheiser headphones and when i play cod4 i only here on one speaker not the second one as...
Windows 7 problem not working of audio sound,no scf sca
I'v buyed Dell studio 1555 with Windows 7 Home Premium(64 bit).I had uninstalled power dvd(pre installed by Dell) using Revo uninstaller ,inadvertently I deleted some of the registry files. Now facing various problems... First there is no audio sound(no mp3,no login sound, no keypad sound..).. ...
General Discussion
sound/AUDIO problem on HP COMPAQ DC7100
Hey guys, I've installed Windows 7 and it really looks neat and fast, but I have one problem and it's getting my soundcard working. I've downloaded the vista drivers from HP from HP Compaq dc7100 Small Form Factor PC -  Download drivers and software - HP Business Support Center Ive run...
External sound card audio problem windows 7
Hey guys i just installed windows 7 evrything is just great except i just cant find the required drivers ,i don' t really know what make my soundcard is and the driver bundle with that does'nt seems to work . ill post the dxdiag details here ,any help will be appreciated . ------------------...
