Windows 7: Not getting any sound to my 5.1 from Digi Optical cable
09 Mar 2010   #31
Windows 7 64 & Ubuntu 64
Quote   Quote: Originally Posted by stormy13 View Post
You set it to stereo/2.0/2.1?
Yeah see the pic above where I have the Turtle Beach control panel, its set to 2 speakers in the middle there...
Search this Thread:
Advanced Search
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
No sound through SPDIF out (red) Optical.
Hi, I have a Gigabyte GA-Z68X-UD3h-B3 Motherboard, which has a SPDIF out port on it. I followed the instructions by going into the Realtek Audio manager and setting it to "Digital Output (Optical) " and when I test it, no sound comes out, it is hooked up to a Vizio HD Tv, Im using a Nvidia 8800 GT...
Optical cable recognised as HDMI
Hello everybody, I have a Windows 7 enterprise 64 bit pc and an Onkyo receiver. I used to have them linked with an aux cable for music. But since I had enough of the bad sound quality I bought an optical cable and connected it. Now I have the problem that my subwoofer gives a lot of less sound...
Hardware & Devices
Sound didnt return after using DVI-to-HDMI cable
My friend has a computer that I helped build. I was testing to see if using a DVI cable would increase his graphics. It is DVI to HDMI and a message appeared that said sound was no going to go through the DVI. Well, we switched back to VGA and he has no sound. Is there an option to set it back...
Hardware & Devices
No sound through the HDMI cable
I have a TV with HDMI and when possessed Vista both the sound and image were transmitted by cable, put the 7 and only the image is transmitted on television, the sound driver is installed and supports HDMI transmission is the same as used in Vista. How can you fix the problem? I did not know...
Don't know were to put audio cable in hd sound input
I got a Compaq Persario V3000 and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable. There are two Speakers which I know were to put them but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack Please help me.I know it...
