Not getting any sound to my 5.1 from Digi Optical cable
JohnnyScience
Power User
1:09 AM
I just hooked up my 5.1 surround sound system via a digital optical cable & I'm not getting any sound?
Its hooked up through my sound card
I've had this working no problem before I moved. I have everything plugged in & the SAT as the preset for the sony 5.1
The sound card is pumping music out of my little desktop speaker via a 3.5 mm jack just fine though?
Windows 7 64 & Ubuntu 64Intel Quad Core Q6600 2.40GHz8gNvidia 9600 GT & 9800 GT
Built it myself
Asus
8g
Turtle Beach 5.1
Three 19" Dell's & one 46" Samsung 750
anyone?
Built it myself
Asus
8g
Turtle Beach 5.1
I'm still dead in the water with my midi controller until I figure this out.
I just don't undestsnd everything is connected properly, shouldn't it just work? The 3.5mm works if I unplug it and plug it back in?
Built it myself
Asus
8g
Turtle Beach 5.1
Did you remember to change the default to digital or spdif in either the Windows audio properties or the cards own control panel?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
See this pic I just tried that again & the s/spif meter gets a signal but nothing is coming out of the speakers or the subwoofer...
What could it be? The optical cable isnt bent or cracked or anything?
Built it myself
Asus
8g
Turtle Beach 5.1
Looks to me like you still have the onboard audio enabled and without the drivers installed. You also don't have your TB card selected as the default playback device, but the onboard.
If you aren't going to be using the onboard audio, go into the bios and disable it.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
hmm ok. I can do it with a little help. How/where should I go into bios & what section will I need to go to in order to disable the onboard audio?
I thought I had the drivers installed for the turtle beach sound card... it seems to register under sound as you can see by the last pic?
Built it myself
Asus
8g
Turtle Beach 5.1
They are and shows in that screen shot. Also,
As for how to enter the bios and disable the onboard sound, read the manual that came with your motherboard, or download it from the manufacturer.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ok so I went in my bios & found the only section that was refering to sound & disabled it & then it actually removed my s/pfid setting...
See here, it shows enabled now because I took the picture of the bios after I changed it back but the Sound control settings was taken while it was disabled after a restart...
Built it myself
Asus
8g
Turtle Beach 5.1
still stuck on this, any ideas?
Built it myself
Asus
8g
Turtle Beach 5.1
I dont get it, I have my computer speaker working through my sound card via 3.5mm jack, but yet the optical that is on the same sound card isnt working even when I set s/pfid as default in the sound settings? (The meter still moves, but no sound at all?)
Built it myself
Asus
8g
Turtle Beach 5.1
I've posted on the Asus forums in helps to disable the onboard sound, so hopefully we can get to the bottom of this very soon. (I've got a music project due monday)
Built it myself
Asus
8g
Turtle Beach 5.1
bump
Built it myself
Asus
8g
Turtle Beach 5.1
Go into the Device Manager and disable the onboard sound.
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ok I did all of that & tried both 44.1 & 48khz & still nothing. The meter bar inside of the sound device is moving, but I dont even get anything to my sub..
I tried to disable everything other thand the s/pdif & it still didnt work and now the other options are gone for me to enable them again - how do I do re-enable them?
Any other ideas?
Built it myself
Asus
8g
Turtle Beach 5.1
still stuck...
Built it myself
Asus
8g
Turtle Beach 5.1
any help on this? I have another sound project due tomorrow & if I dont get this working I cant do the project.
thanks
Built it myself
Asus
8g
Turtle Beach 5.1
are you connecting this sound card to an (receiver/amp) or 5.1 speakers? what kind?
you might want to check and see how many s/pdif ports you have on the back of each.
I know i have 3 on my computer, 1 in > 2 out ..
and on my receiver i have 2 1 in > 1 out
though i use an x-fi card..
Windows 7 64BitIntel Core 2 Quad Q9550 (Yorkfield) 2.83GHzg.skill 8 GigsNVIDIA GeForce GTX 260 896 MB memory
Windows 7 64Bit
ASUS STRIKER II FORMULA
g.skill 8 Gigs
Soundmax Xfi
Acer H213H 23" wide
WDC WD10
BFG 800PSU
Fans :)
yeah there is only 1 optical port on my card & my sony 5.1 - the surround plugs right into the dvd/amp (its a box kit 5.1, but its still nice)
I used to have it hooked up fine on XP Pro, but I dont think I've ever tried setting it up on 7 until now.
But I'm still stuck?
Built it myself
Asus
8g
Turtle Beach 5.1
