Sound Mixer Doesn't Retain Settings After Reboot
seekermeister
Old School
10:16 PM
Indian Territory
I get all of the sound settings exactly how I want them, and invariably upon rebooting, all of the sliders go up to the maximum. This is somewhat annoying, but even more so for some apps, like my email client, which is set to play a sound when an email is received. The reason being that the client doesn't appear in the sound mixer, until it receive a message to notify you about. As luck would have it, it seems that this most often occurs after going to bed, only to be aroused by the sound of "You've got mail" blasting so loudy that I'm probably awakening my neighbors also.
Is there a way to tweak this, so that it will always speak softly?
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
Hi dude,
Try modifying these options and restart. Lets see if this could help you :)
Windows 7 Ultimate x64 SP1Intel Core i34 GB DDR3
Dell Inspiron N5010
Intel Core i3
4 GB DDR3
1366 X 768
Seagate 500 GB
4 MBPS
I'll try it, but I don't think that it will work, because if it doesn't do anything, it wouldn't play the sound at all...would it?
DIY
3.3Mbps
(** = 2nd rig)
* Enabling and disabling an option would fix some issues at times. So, its just a trial and error. Try first and second options :)
* Meanwhile, I will think of other solutions
Dell Inspiron N5010
Intel Core i3
4 GB DDR3
1366 X 768
Seagate 500 GB
4 MBPS
You can stop thinking about it, because it seems to have worked. I thank you and my neighbors thank you.
DIY
3.3Mbps
(** = 2nd rig)
Oh thats great to hear buddy :)
♥ Cheers ♥
Dell Inspiron N5010
Intel Core i3
4 GB DDR3
1366 X 768
Seagate 500 GB
4 MBPS
