Windows 7: Taskbar volume icon problem
25 Feb 2010   #11
Windows 7 Home 64bit
Well... i opened my computer this morning and all the system icons where off and greyed out like usual.
26 Feb 2010   #12
I think i might have to reformat, that should probably fix my problem, right?
26 Feb 2010   #13
64-bit Windows 10 Pro
I would try a repair install first to see if you can avoid a full clean install. This way you will not lose anything.
26 Dec 2012   #14
I have found the answer.
Some How the icons are hiding underneath eachother.
so grab the top of the taskbar pull it up and then move it back down and the icons will be organized in the right order again.
no fortmatting.
no Restarting.
Really Simple..
Search this Thread:
Advanced Search
My Volume icon no longer shows on my taskbar, ( Picture included )
hello i did something by mistake with my mouse and i dunno what happened, my volume icon no longer shows up, i tried to activate it back but i cannot. this picture might explain it. i try to turn it on but i cannot even click it picture in attachment please help me, Thanks
FireFox Taskbar Icon, Makes Duplicate Taskbar Icon's
For some reason FireFox doesnt want me to use my own icon for it in the taskbar. ill change the icon, pin it to the taskbar, click the new icon and itll open up a new firefox default icon on the taskbar so there will be 2. anyway around this?
Browsers & Mail
How do I get the volume icon back on the taskbar?
Hi there. The icon which controls volume which used to be on the lower left corner of my taskbar has disappeared. When I go into "Customise" then "Turn system icons on and off", I am unable to turn the "Volume" to "On". Any ideas? Sorry if this problem sounds really trivial, just...
Windows 7 Taskbar Icon Problem
When I Hover Over An Icon On The Taskbar Like In The Picture Any Help?
General Discussion
Taskbar icon problem for browsers
I have Firefox & IE pinned to the taskbar. Up until recently, if I clicked on either of the icons they would open but also leave the icon on the taskbar. I could then click it again & a new window would open. Now if I click on one of the icons a window will open but the (plain) icon...
