TV sound through to computer then to 5.1 system?
Tarka Dal
Pro User
4:44 PM
Can anyone tell me if this is possible?
Stools
Stools
It should be possible assuming you have both an Input and Output spot on your sound card. Sadly I've never experimented with doing this so I can't verify it works. Personally, I just port everything through my receiver. Computer included. Any particular reason why you want to set it up this way? :)
Windows 7AMD Phenom II X4 955 Black Edition8GBPNY XLR8 GeForce GTX 460 1024MB GDDR5
MSI 870A-G54
8GB
2 x 24"
I don't have a reciever and that would cost £565 so i don't want to spend that much!
Stools
Stools
Ahh ok. Well, I really don't see why you couldn't. There is a line in port on most audio cards. Don't know what kind of quality you'll get though, depends on the audio card :)
MSI 870A-G54
8GB
2 x 24"
I'll have a look for one now then.
Stools
Stools
The green port is out and the blue port is input if I remember correctly. You'll most likely also need to grab yourself a wire with RCA on one end, and the small headphone type jack on the other end.
MSI 870A-G54
8GB
2 x 24"
Money,money,money,money,money,money etc.
Just thought I'd come back to this, yes it is possible to do it but the right answer is to go out and buy a new 5.1 surround sound system with HDMI if you can afford it!
Stools
Stools
