Windows 7: Sound Driver Problem with Win7
06 Mar 2010   #1
alturki
Hi every body . how are you
I've got a problem with my sound card . Win7 can't see it and i was searching for the Setup + the Upgrade for it and i found nothing
now i'm using USB Speakers and that doesn't work with the games ( online ) it needs the real sound card not the USB
please can you help me with this ?
p.s if it didn't work i'm going to change my Computer to XP
06 Mar 2010   #2
DocBrown
Intel DP965LT
From Intel website:
Windows 7* Driver Availability for Discontinued Intel® Desktop Boards To begin the download process, click Download.
For additional details about this download, click Read Me or Release Notes (not available for all downloads).
Intel does not currently plan to develop and offer Windows 7 drivers for any of the discontinued desktop boards listed below. For a list of supported operating systems for Intel® Desktop Boards, refer to Supported Operating Systems.
Have you tried the XP drivers in compatability mode ?
06 Mar 2010   #3
alturki
i tried them but nothing works . i was searching @ Intel website and i found nothing
07 Mar 2010   #4
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by alturki View Post
Since there are no Win-7 drivers... have you tried the Vista 32/64 drivers.
These should work.
Audio: IDT* 92XX Driver
You have the audio enabled in the BIOS, correct, remove all ither audio drivers before installing these.
Ap
07 Mar 2010   #5
alturki
I TRIED THIS but it says Error : o_O'
The Hardware detected is not supported by this IDT Software Package . This install will be aborted
i see this error every time i try to install the driver
so how can i fix it ?
Well I had Windows XP ages ago and I did a a upgrade to Windows 7 Ultimate with a clean install of it and when I got it my Realtek driver was losted and my soundcard is gone so I download the driver again but still my sound didn't work , I went to a computer shop and I got fixed and it worked but ,...
Problem with sound driver
Hi, I just upgrade my pc from win xp to win 7, and it seems win 7 installed all my drivers automatically but not the sound drivers. I had problems with the sound driver back in the xp days too. My system detect my sound driver as via ac'97 enhanced audio controller all the time but the driver does...
Drivers
Sound problem on win7
Hi i have a problem whit sound on win 7. I use sound card on my motherboard Gigabyte M57SLI-S4 and realtek drivers. Bat here is a problem realtek detect my speakrs, and when i select it on 5.1 and when i click test (sound) i hear thet the speakers work great. bat when i open youtube or play some...
Hardware & Devices
Creative Sound Blaster 5.1 SB 0220 WIN7 32 BIT DRIVER ?
hi I need Creative Sound Blaster 5.1 SB 0220 WIN 7 32 BIT DRIVER ... which support pack ? thanks ...
Sound driver problem on XP
I hope someone here can help with this. It's regarding the highlighted entry in the attached screenshot. The driver shows an error but I can't seem to fix this. None of the right-click options do anything. I can't install a new driver, I can't update it, I can't uninstall it... WTH? How...
Hardware & Devices
Problem with sound card driver
Well i have a 5.1 PCI surround cart SL-8866-SRD and we i install the driver it says "Can't find your device. Please plug in your device and press Retry to continue" what should i do? PS:I have connected the sound card, that's why i am confused.
Drivers
