Ventrilo Lag help please.
  1. Posts : 9
    MS Windows 7 Ultimate 64-bit
    Hi everyone,
    I'm not sure how many of you use Ventrilo to play online games (i.e. CS 1.6) but I've had a few minor issues with the program. For starters I've had this problem in both the 32-bit and 64-bit version of the program. The issue is sporadic but happens every time I run the program. Voice chat will appear to be working just fine, however after a few minutes you'll notice that when you talk there are no immediate responses. After a few minutes more you hear all the previous dialog linked together in one big audio stream, like it lagged and tried to catch-up in fast-forward. Has anyone else experienced this?
  2. Posts : 9
  3. Posts : 1
    Gateway
    I Have this problem too. Its only when i talk to more than 1 person though. With skype and Ventrilo. I can talk to 1 person just fine and it never happens but if i do a conference call on skype or if i am in a ventrilo channel with more than 1 person it happens. Also when i talk on skype it breaks in and out but on vent i never break up.
  4. Posts : 9
    I have found "somewhat" of a trick to fix this a bit. Press Ctrl+Alt+Del and open "Task Manager", go to the "Applications" tab, and right click Vent, Skype, etc. and click on go to process, then right click on the process and click on "Set Priority" and then on "Realtime". This usually works for me, although on rare occasions it will still happen.
    **You have to do this every single time you use Vent or skype or w.e. Hope this helps :)**
