Windows 7: Desire to separate master sound control from devices
07 Mar 2010   #1
wkool
I am running Windows 7 on a nearly brand-new HP Pavilion DV6. I am trying to use Audacity to record a live radio stream playing in Windows Media Player. I am trying to use the Volume Control to do what I am trying to do: In order for the Audacity recording to be of sufficient volume for playback, I have to turn up the sound on Windows Media Player in the Volume Control. This necessitates me also turning up the "master" volume on the speakers in the Volume Control because putting the "master" volume low sets a governor on all the other volumes. But I don't WANT the speakers to blare. I just want to turn up the "internal" volume on Windows Media Player so I can record this properly!
My speakers are directly linked to that "master" volume control.
Can I remove the governor link between the "master" volume and the individual program/device volumes? That would be exactly what I need, and there was no governor in Windows XP.
See screenshot attached.
--Wkool
07 Mar 2010   #2
BugMeister
- what hardware are you using for audio..?
07 Mar 2010   #3
wkool
I am using the internal speakers of the laptop. There is no "hardware" volume adjuster for them. They are controlled by the touch-slider above the keyboard. This touch slider is linked with the "master" volume I mentioned before. If I change the touch-slider, the "master" volume changes identically, and vice versa.
Renaming Devices in Windows Sound Control Panel
If I rename audio devices by the method indicated below, will there be any negative repercussions? I would assume that programs don't use those names to identify devices, but I want to double check. http://i.imgur.com/5YXM0.jpg
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
How to play different audio from two separate devices
I like to play different games, and stream movies or shows at the same time on my TV which is hooked up. I recently upgraded my comp to a full custom build (z77 sabertooth, i5-3570k, 16GB ram, Windows 7 Professional 64 bit) and can't figure out how to set my audio playback devices to play...
Master volume does not control USB speakers
I connected a DAC to my laptop and set it as the default device from the control panel. Now the master volume mixer does not work at all. When I change change the "master volume" slider - the others (WMP, firefox, etc...) apparently change with it too but there is no effect on the actual...
Desire to keep WinXP on Mirror RAID with Win7 on separate HDD
Simplest thing to do is to just load W7 and get it over with...but am just smart or stupid enough to consider alternatives... I have a pretty stable WinXP install but have run into games that require 7 (and DirectX 10). Question: Can I install W7 on a non-raid HDD (already on my machine)...
Installation & Setup
