Realtek Mute Rear output when front input is plugged in
flamingkitties
11:07 PM
A field outside Preston, Lancashire, UK
This doesn't work. Very irritating.
(I don't know if this RealTek sticky at the top of this forum is a solve for this, I'm not hot on registry changes and I'm not sure if this is a fix for this issue.)
Firstly I have to turn off the front-panel detection in order for the front panel to be detected..?
Secondly, I can't get the speakers to mute when the front phones are plugged in. I can do a manual switch from one to the other, but the front panel won't detect when things are plugged in.
Is it fixable?
Danke!
Windows 7 Home Premium 64 bitIntel Core i5 2500k8gb Corsair VengeanceSapphire HD 7770 OC Edition 1024mMB
Own
Intel Core i5 2500k
Gigabyte Z68X-UD3P Intel Z68
Onboard 7.1
Viewsonic VX2260wm 22 inch Widescreen LCD Monitor
120GB OCZ Agility SSD
1TB Samsung HD103SJ
Something I forget with 700w
BitFenix Shinobi White
Cool IT eco ALC water cooler
Saitek Eclipse II
Roccat Kone+
Sorry, but no. You will have a Realtek HD codec on board, and, like many others (myself included), are having to use an AC'97 front panel. These will work, but there are limitations like you have mentioned. The only way that you can have the speakers that are connected to the rear panel (the motherboard connectors) mute automatically when plugging headphones into the front panel is to have a HD compliant unit.
See http://www.sevenforums.com/sound-audio/44491-ac97-hd-audio-front-panel-layouts.html for an explanation.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Thanks for letting me know (rather than going through another half hour of switching of tick boxes randomly in hope something would get it to work). If the only option is to switch the default output manally, it's still much better than having to scramble behind the computer desk each time to plug and re-plug things.
NB: tomorrow I get a new graphics card, I'll be back here (on the Mac no doubt) to cry about that too I expect ;)
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
One last thing.
My audio is set up as working now, I switch between speakers or phones out with the manager.
However, an anomaly. Speakers are set to default, I turn Warcraft on and the sound only comes out the front headphone socket. If I take the headphones out, no sound at all. What's going on?
Edit: my bad, it's an in-game setting. Ignore my ignorance.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
Riddle me this.
I had my speakers plugged into a different computer the last few days where I needed them to be.
I plugged them back into the green port in my PC today only to find they now won't output sound (although they are according to the Realtek thing), I haven't changed any settings, they are plugged in properly, there's no headphones in the speakers - although the phones are plugged into the front port (and work). I've unplugged the front port and still no sound from the rear plugged speakers.
What the heck has happened? I'm missing something obvious, I'm sure.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
Have you plugged the speakers into the power supply? Most speakers are active, which means that they have a built-in amplifier. Of course, this also means that they need connecting to a source of power, as well as to a signal source.
Gigabyte IF233
Avast! 8.0.1497
IE 11
I may look it, but I'm not that stupid!
The speakers are on, the led is on, my mobile phone's interference sound comes through the speakers (as usual), and the speakers worked fine when I plugged them into my Mac to work on a video project the last three days.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
Ok a little :confused: but yeah you have mobile phone plugged in? ..unplug that re-plug in the speakers and restart, did you change something on the advanced settings on the realtek HD Manager?
Win7 Home Premium x64 SP1, Archlinux x86_64. ...
Win7 Home Premium x64 SP1, Archlinux x86_64. Elementary Luna
No, I find my carrier's signal is loud, you know the signal it sends to keep in touch with the nearest cell tower, it does it quite often and is picked up by the speaker if it is nearby.
Speakers definitely work, I plugged another device into them.
I only started fiddling with the manager when it stopped working. As far as I can tell it's back on the settings which worked for me once I'd sussed them out. Most peculiar.
Edit: also, when fiddling with the setting of the speaker port, setting it to rear speaker, the speaker popped when it came back on via me clicking that setting.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
Ok so you have the phone plugged in the front? and the speakers in the back are muted? soo it'd make sense at theres no output .. go to the Realtek Manager and click device advanced settings and change it to " Make front and rear output playback two def......" another way to try to get the speakers tested is open WMP > Options > Devices Click on Speakers.
then change the default to your Speakers (not phone ones).
forgive me if im no help :confused:
Edit: also try going to the Speaker icon in your notification area Click it and click System Sounds .. new windows will pop up .. go to the playback tab and fiddle with those settings if you missed something.
Phone - headphones.
Sorry, I meant my telephone, mobile/cell made the bleepy noise, not the 'phones'.
Speakers at the back won't manually mute - I switch manually between headphones and speakers when I want to switch on the Realtek manager. That setting you've suggested is already ticked.
Nothing changed, speaker wise in WMP, songs play, no sound comes out, despite speakers being selected either when they are switched to default or specifically to speakers. Humm.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
Hmm i also switch between my headphones and speakers also. but for one to get detected i had to 1st have one of course plugged in then plug in the other one and reboot and vice versa but since i bought USB Headphones it's easy switching between the two (no rebooting).. dunno really what to say :\
Well it was working fine until today, so, I will cross my fingers and hope it just sorts itself out, things usually do. If not, I may uninstall and reinstall the Realtek software and see what occurs.
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
It is doable, at least with mine drivers. I use the VIA HD Audio Deck to do this:
Windows 7 Enterprise 64-bitAMD Phenom II X4 3.0GHz8GB G-Skill Ripjaws DDR3 1333PNY GeForce 460 GTX 1GB OC - Enthusiast Edition
ASUS M5A97
VIA High Definition Audio
Dell 19"
1280x1024
1TB - Primary
160GB - Secondary
250GB - External backup for important files
OCZ Fata1ty 700W Modular PSU
ASUS
Microsoft Wireless Keyboard 2000
Microsoft Wireless Mouse 2000
3 Mbps/768 kbps
Yeah sorry, I don't think changing software / re-installing is really needed though but who knows might work. as i see Product FRED's Manager is easy to understand
No setting has changed. As far as I know. Drivers are up to date. Can I used another sound manager if my device is Realtek?
Own
Intel Core i5 2500k
Onboard 7.1
1TB Samsung HD103SJ
Saitek Eclipse II
Roccat Kone+
necrophilia but still problems....
ok, i had the same problem upon changing my mobo to asus F1a75 evo
so with all my fingers crossed, i switched the pin on my chieftec case from ac97 to azalia, and in bios turned it to HD.
still the same problem. rear speakers dont mute when i connect the headphones.
md
win 7 x64 ulti
win 7 x64 ulti
