Windows 7: Volume Control wont move sound card slider
12 Mar 2010   #1
samsung3D
I have E-MU 1212M sound card, Windows 7 and I can't fix this problem which I haven't had before. I reinstalled the Windows 7 and now I can't move my Volume Control and affect my sound card volume. My sound card volume wont move until I move it.
It's like my volume mixer is pre-effected,before my sound card.
any help will be appreciated, Thank you
12 Mar 2010   #2
FZ21Z
Quote   Quote: Originally Posted by samsung3D View Post
Did it before? The Windows volume control doesn't affect any of my players volumes, so if I have Winamp open for example, adjusting the volume with the Windows mixer control doesn't move the Winamp slider, nor does it move the WMP slider, which is why I leave Windows volume at full, and adjust the volume from within what ever program I'm using to watch a film or play music.
12 Mar 2010   #3
samsung3D
I know that the program slider wont move but when I was moving the Windows Volume Mixer, the Master volume slider of my sound card moved too. But now it isn't like before. See the picture, the Windows Volume Slider (master) is moved around 45-50% but the sound card slider wont move,it's still 0.
tnx for the fast response
12 Mar 2010   #4
FZ21Z
If it did it before, all I can suggest is the usual, uninstall then reinstall the card and the software to see if that helps.
27 Mar 2010   #5
samsung3D
I found the solution!
I was searching for this type of problem but there is no other problem like this one (I didn't find on internet).
I use AIMP 2 and my EMU 1212m sound card. And in the AIMP preferences it has option "Global Volume Controlling", it was disabled, and I enabled it. There is a picture for how it looks like after I checked the "Global Volume Controlling". Now when I use my Media Buttons on my keyboard for changing the volume, Master Volume on my sound card moves too! After a month I found the solution. Thank you for any help you provided... I appreciate that.
I upload the pictures for people who has the same problem, or maybe an inspiration for similar problems like this one.
Volume Control wont move sound card slider-media-keyboard.jpg Volume Control wont move sound card slider-capture-2.png
18 Mar 2012   #6
Doors7
Here is how you do it !!
1. Go to 'Options' or 'Preferences' in AIMP Player.
2. Click on 'Hot Keys' under 'Player'.
3. Delete (click on the 'X' mark that appears when you click inside the cells for 'Local', Global 1', Global 2' etc.) all the entries against 'Volume -' and 'Volume +'
Thatz it !!
Now your default Playback device will be enabled and you can control the Volume from your Keyboard
Can't control gain! No slider in control panel!
Hello! I got myself an Audio-Technica AT2020USB+ condenser microphone a few weeks ago, and I haven't really found out how I can change the gain, which I hear is important to do. There is only one slider where the gain slider also should have been. The mic doesn't have a gain know like some other...
sound volume control problem in WMC
Hi, I have only one small problem with the sound volume control in WMC. I have a new HTPC, pumpimg sound out via a Digital coax cable to Logitec z5500 speakers. This works just fine, sounds great etc, except..... The sound volume control in WMC doe not work when watching Live TV, or TV accessed...
Media Center
Creative sound card, windows 7 compatible volume control?
I recently bought a dell computer second-hand from my friend, who had XP installed on it. It came with a subwoofer and a set of 4 regular speakers. On it, he had installed a form of creative volume control in addition to windows volume. The way it worked was he had the windows volume set to 100%...
Green Bar in Volume Control is Moving, No Sound
I have speakers plugged in to my computer running Windows 7 Home Premium 64Bit. The computer is recognizing that I have speakers plugged in and when I play something the green bar moves with the music. However, no sound is coming from the speakers. I have gone into the BIOS settings and enabled...
Sound unmuting when I touch volume control?
Is there anyway I can disable the sound unmuting when i turn the volume control knob? Vista didn't do this and it's really annoying as its on the bottom so i always catch it when the laptop is on my lap.
Show sound slider when adjusting volume?
I used to have a volume bar in XP, but those drivers no longer work. I have no visual indicator of system volume. That's significant when viewing online media because the system may be maxed out, while the media player may not. I'd absolutely love the Win7 sound slider to show up when I turn...
