Windows 7: Sound Problem!
14 Mar 2010   #1
Sound Problem!
I have 5.1 Audio Card SL-8866-SRD 5.1 PCI.I can watch DVD normally with 5.1 sound but when i play some music the sound get's out only from the 2 speakers and the sub.I want to get the sound to come out of all six speakers but it will still only be in two channel mode but i dont know how to do that can somebody help!
30 Mar 2010   #2
Windows 7 Ultimate Professional x64
What are you using to play these songs? Also, where are these songs from?
This will help determine if the songs are able to be played.
Let us know,
07 Sep 2010   #3
Windows 7 Home Premium x 64
You need to know that all music is not designed to be heard through all the speakers.
(aka channels) A lot of DVDs are designed to take advantage of 5.1 surround sounds.
But in contrast, most music arent designed to take advantage of 5.1. Maybe just stereo? (Two Channels) So the most important element to know is the source you are trying to play? 1) Is the source I am trying to play designed to be in 5.1. 2) Does the device I am trying to play have the ability to read the codec?(aka 5.1 surround) and 3) do I have the device set properly for it to work? I hope that helped?
 Sound Problem!
Search this Thread:
Advanced Search
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: The problem was that the volume levels were off, and...
Sound problem
Hi all, I had this problem with my laptop sound randomly disappears and it comes back after a while like 15 min or so.I have Realtek HD Audio Driver installed.Is it problem with my driver? Can anyone help me with this? i am despreate !!!
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
sound problem
Hello, I have a sound problem on my HP Pavillon desktop (windows 7). Everytime, after some hours of use, I hear sound clicks&pops. I restart, and the problem is back after some hours. When sound clicks&pops occurs, I see abnormal CPU usage in task manager. Like going back and forth...
