Windows 7: Using Some Audio Programs At The Same Time
02 Aug 2011   #11
Windows 7 Professional 64 bit
Windows 7 won't play MP3's
Quote   Quote: Originally Posted by Aphelion View Post
Quote   Quote: Originally Posted by hadoitz View Post
My notebook is Acer Aspire 4736, with Realtek audio, and ASIO4ALL driver.
I use AmpliTube as a virtual guitar amp on my laptop.
When I still on Windows XP, I can use AmpliTube, Guitar Pro, Windows Media Player all at the same time.
After upgrading to Windows 7, I can't even use WMP and AmpliTube at the same time.
WMP keeps showing "Windows Media Player encountered a problem while playing the file." until I close AmpliTube.
How can I fix this ?
I really need to use AmpliTube togehter with a few other programs
Try this...
Right click on the Microsoft Speaker icon in the system tray.
Select "Playback Devices".
Select "Speakers" (or whatever your default playback device is)
Select the properties button at the bottom right then select the advanced tab.
De-select both of the options available.
-Don't know if this will work, seems like it might help.
While your in properties, might want to disable all of the enhancements.
Thanks for the suggestion. In my case: brandnew HP ProBook 4720s, Windows 7 professional 64 bit.
I installed WinAmp 5.6.2. Would not produce sound: it reads MP3s and shows in the spectrum view that it can read the file .. for a fraction of a second, yet doesn't produce sound and immediately stops.
I tried the native MediaPlayer, which would result in the statement that it cannot play the file because an error occurred.
I tried iTunes. No sound.
I tried VLC Media Player. This one would "playback" the file, in that it would show in the spectrum visualisation that it reads the files, yet wouldn' produce sound.
So, I followed the above suggestions. Simply upon opening the last advanced properties window ... sound appeared, without even changing any settings ...
I don't bother to figure out why that is. Maybe it's useful for someone else too ;-)
12 Mar 2015   #12
Windows 8.1 Pro 66 bit
Try "O Deus ASIO Link"
- Install ASIO Link
- Open your sound procesing software (Amplitube) and choose the "Link (ASIO)" driver
- Open ASIO Link and choose your HW ASIO driver
- In ASIO Link click in the channel maps to achieve the desired mapping/mixing between your HW ASIO driver and the WDM driver (see attached image)
BR Henrik
Search this Thread:
Advanced Search
Using two audio devices the same time...
How can I use both my Usb headset and the 3.5mm phono jack speakers playing at the same time and even two microphones one that is USB and other that is 3.5mm jack? How about using two 3.5mm jack devices?
Nfo old time radio programs
Old-time radio is a lot of fun. You’ll find free, legal old-time radio programs online. The Internet Archive has a large selection of old radio programs such as Sherlock Holmes, Dragnet and World War II news broadcasts. You can download the episodes in MP3 format. They’ll work on any music player,...
Chillout Room
No sound from audio programs?
I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix...
Same old UAC dialogues, each time certain programs run
Every time I run certain programs (e.g Winamp or Ext2FSD), Windows asks if I don't mind the program making changes to my harddisk. Of course, this has rapidly become very irksome. Most firewall software, indeed most software generally, at least have an option to save my response and refer to it in...
System Security
two audio devices at the same time
hi together.. i have three audio devices on my system. a Creative SB X-Fi, a Logitech Z-10 USB Speaker and a Trekstor SoundBox USB Speaker (wireless). I would like to use the Logitech Z-10 USB Speaker or the Creative SB X-Fi and the Trekstor SoundBox USB Speaker (wireless) at the same time...
M-Audio Audiophile 2496 sound hanging/stuttering from time to time
hey guys, i just bought a new M-Audio Audiophile 2496 soundcard to enjoy great sound in a foobar2000 + flac combination. i've successfully installed the Vista 32bit drivers in compatibility mode and everything worked fine until then. after starting to listen to music, i've experienced that...
