| Windows 7: Using Some Audio Programs At The Same Time |
15 Mar 2010
#1 | | |
Using Some Audio Programs At The Same Time My notebook is Acer Aspire 4736, with Realtek audio, and ASIO4ALL driver.
I use AmpliTube as a virtual guitar amp on my laptop.
When I still on Windows XP, I can use AmpliTube, Guitar Pro, Windows Media Player all at the same time.
After upgrading to Windows 7, I can't even use WMP and AmpliTube at the same time.
WMP keeps showing "Windows Media Player encountered a problem while playing the file." until I close AmpliTube.
How can I fix this ?
I really need to use AmpliTube togehter with a few other programs
Thanks | My System Specs |
| System Manufacturer/Model Number Acer Aspire 4736 OS Windows 7 |
15 Mar 2010
#2 | | Windows 7 Home Premium Southwest U.S. |
Quote: Originally Posted by hadoitz My notebook is Acer Aspire 4736, with Realtek audio, and ASIO4ALL driver.
Thanks  Try this...
Right click on the Microsoft Speaker icon in the system tray.
Select "Playback Devices".
Select "Speakers" (or whatever your default playback device is)
Select the properties button at the bottom right then select the advanced tab.
De-select both of the options available.
-Don't know if this will work, seems like it might help.
While your in properties, might want to disable all of the enhancements.
Ap | My System Specs | | System Manufacturer/Model Number Assembled in my workshop OS Windows 7 Home Premium CPU Intel Core 2 Duo @ 3.00gHz Motherboard Gigabyte GA-P35-S3G Memory 4 GB Graphics Card ATI Radeon HD 2600 XT Sound Card RME 24/96 Card, Realtek Internal Audio PreSonus FireStudio Monitor(s) Displays Acer 1917 (x2) Screen Resolution 1280 x 1024 on both monitors Keyboard Macally w/2/USB ports. Mouse Trackman Wheel PSU Rosewill 500-watt Case Rosewill mid-tower Cooling Noctua NH-U9B (CPU), PwrSupply fan + single large case Fan Hard Drives Three 250GB Seagate SATA Barracuda 7200rpm Other Info Event 20/20 bas studio monitors, Yamaha sub.
Cubase MIDI/audio recording. Sony Soundforge audio/mastering software. CD Architect Mastering. RME & Presonus audio interfaces. |
15 Mar 2010
#3 | | |
Ap I've tried disabling the exclusive mode and disabling all of the enhancements.
It still doesn't work
But thanks for your help Aphelion | My System Specs | | System Manufacturer/Model Number Acer Aspire 4736 OS Windows 7 |
15 Mar 2010
#4 | | Windows 7 Home Premium Southwest U.S. |
Quote: Originally Posted by hadoitz I've tried disabling the exclusive mode and disabling all of the enhancements.
No problem, Windows-7 audio can be such a pain sometimes...
Have you also removed the exclusive mode for the Default Input? (recording devices) Also, since the exclusive mode is not global, I wonder if it would be a good idea to de-select it for all devices both playback and recording.
Are you using the stand-alone version of Amplitude, does it also ship as a VST plugin? Is Amplitude the one that has the Fender amp emulation?
I imagine you're using the ASIO4All in Amplitude as the low-latency driver, is it a different version of ASIO4All betwenn WinXP and Windows 7?
A lot of questions, sorry.
15 Mar 2010
#5 | | |
Quote: Originally Posted by Aphelion Have you also removed the exclusive mode for the Default Input? (recording devices) Also, since the exclusive mode is not global, I wonder if it would be a good idea to de-select it for all devices both playback and recording. Yes, I've also tried de-select exclusive mode on recording, microphone, digital input, etc.
Quote: Originally Posted by Aphelion Are you using the stand-alone version of Amplitude, does it also ship as a VST plugin? Is Amplitude the one that has the Fender amp emulation? I'm using stand-alone version, but sometimes also use it as VST in Adobe Audition.
It's AmpliTube Metal, not the Fender amp emulations.
Quote: Originally Posted by Aphelion I imagine you're using the ASIO4All in Amplitude as the low-latency driver, is it a different version of ASIO4All betwenn WinXP and Windows 7? Yes, it reduces the latency significantly.
It's the same version with XP, ASIO4ALL 2.10 beta 1 | My System Specs | | System Manufacturer/Model Number Acer Aspire 4736 OS Windows 7 |
15 Mar 2010
#6 | | Windows 7 Home Premium Southwest U.S. |
Quote: Originally Posted by hadoitz Yes, it reduces the latency significantly.
I have the Realtek audio on board my desktop, I'll try ASIO4All tonight and see how I fare with multiple programs. Don't have Amplitube but do have the standalone versions of Korg's M1 and Wavestation virtual instruments.
I've used ASIO4All before, great little driver.
16 Mar 2010
#7 | | Windows 7 Home Premium Southwest U.S. |
The bad news is... Win-7 or ASIO4All is tying up Direct Sound when it creates the ASIO interface.
I can play multiple audio files using Winamp and Windows Media Player but as soon as ASIO4All is opened Direct Sound is locked.
Might want to drop the author of ASIO4All a note.
16 Mar 2010
#8 | | |
Quote: Originally Posted by Aphelion The bad news is... Win-7 or ASIO4All is tying up Direct Sound when it creates the ASIO interface.
Ap Oh, I see...
Maybe I'll stop using AmpliTube and start using a real amp now
Thank you so much for all your help Ap | My System Specs | | System Manufacturer/Model Number Acer Aspire 4736 OS Windows 7 |
16 Mar 2010
#9 | | Windows 7 Home Premium Southwest U.S. |
Ap Oh, I see...
Thank you so much for all your help Ap  No problem, works in XP though. I'm sure the author of ASIO4All would have some insight.
14 Sep 2010
#10 | | |
Sorry for bumping this old thread, but I have one more question.
If I buy a new soundcard that doesn't use Asio4All for the driver, will it solve the problem ? | My System Specs | | System Manufacturer/Model Number Acer Aspire 4736 OS Windows 7 Using Some Audio Programs At The Same Time problems? All times are GMT -5. The time now is 11:04 AM. | |
