Windows 7: Front Panel - Microphone Do not work,,
15 Mar 2010   #1
mathic
Hi Everyone,
I clean Installed Windows 7 Ultimate 32 bit Headphones were not working in Front panel Jack but Microphone was working in the front panel jack then i gone thru this forum i downloaded and installed AC 97 audio and Realtek High definition sound but in vain,,,,,
Then i installed IDT Audio Control Panel v 1.5 came along with my mobo Disc then Headphone in the frontpanel jack started working but then Microphone stopped working when i click microphone (it is already enabled and checked as default) in the sound menu it gives error "Windows Shell Common DLL has stopped Working" Plz..........Help to come over from this wierd situation.......... Thanx in advance
Regards,
Mathic
15 Mar 2010   #2
zigzag3143
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by mathic View Post
Hi Everyone,
Regards,
Mathic
Any chance you can tell us what MOBO, and sound chipset you have?
19 Mar 2010   #3
mathic
MObo: Mercury PI945GCM Sound Chipset : Realtek
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
Case's audio panel microphone doesn't work
I have recently custom built a PC using an ASUS M5A78L-M/USB3 motherboard in a CiT 2206 MIDI Case. I have downloaded VIA drivers from the motherboard website I linked above, but uninstalled the program that came with it (It didn't manage audio very well and prevented my speakers from working :/ ...
front panel audio jack doesnt work after sleep mode until restart
I have realtek ALC898, part of gigabyte Z77 UD5h mobo, windows 7 ultimate 64bit. Rear jack speakers always work, sound always works. But after sleep, the front panel audio jack does not work, ie headphones silent. Workaround 1) go to device manager, disable realtek high definition audio, then...
Hardware & Devices
front panel audio does not work
Hello everyone I have an hp media center PC m7350n and I have upgraded from Windows XP to Windows 7, I also installed a new graphics card AMD Radeon HD 6450. When I was working on Windows XP my front panel audio was working for my headsets and microphone. Since I've upgraded my headsets and...
Front audio Panel doesn't work (ASUS P7P55D motherboard)
Hey there, I'm using the onboard sound of my ASUS P7P55D motherboard. The back audio connectors work fine, but I somehow can't use the front panel that I connected to the mobo (yellow cable). Is there a trick or any setting to activate it with win7 professional x64? I also tried changing...
