No sound from audio programs?
schumacher574
10:10 AM
California
I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix this?
Note: I updated to the correct windows 7 x64 drivers for M-Audio Delta already, and these programs are both compatible with x64.
System specs:
System Manufacturer/Model Number: Custom Build
OS: Windows 7 64 bit
CPU: Intel i7 860 2.8 GHz
Motherboard: eVGA P55 (Intel P55 Chipset) (Supports SLi)
Memory: CORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Graphics Card(s): eVGA GeForce 9600GT 512MB
Sound Card: M-Audio Delta 1010LT
Hard Drives: 1) 250GB SATA 7,200RPM w/ 16MB Cache
2) 150GB 10,000 RPM 8MB Cache Western Digital Raptor
3) 500GB WD 7200 RPM
PSU: Corsair 750W
Case: Antec 900
Cooling: Maximum case fans
Windows 7 64 bitIntel i7 860 2.8 GHzCORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 ...eVGA GeForce 9600GT 512MB
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
Welcome!
Can Windows Media Player play sound? How about your web browser?
You may want to confirm that the correct output device is set as default. Go to Control Panel>Sound and right-click on your speakers.
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
I hear mouse clicks from the web browser, and one program I installed while setting up the system had music during the installation that was playing. I can't test out Windows Media Player right now because I'm at work...I will try when I get home.
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
I'm running an Audiophile 24/96 without problems, however, I'm not using it as the default audio device. The Audiophile is part of the Delta series and may even use the same driver, it's working fine with Cubase, Winamp...etc.
Are you selecting the ASIO driver in East/West and Cubase?
I'm wondering if using the 1010 as the default audio device is locking out the ASIO part of the driver?
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Just remembered something... this could also be a MIDI/triggering problem, what interface are you using?
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Thanks for the replies...I think it could be a MIDI/triggering issue, as within EastWest products, if I play a note, I see the mixer recognize the initial hit, but it wont hold out notes, and some notes are skipped. I just have an Axiom 61 midi keyboard plugged in via USB, and so far I've just been using the EastWest standalone VST and Cubase 5 to try to get sound. Any suggestions?
I have the M-Audio Delta lines 7/8 (which I'm plugged into) as the selected device in EastWest...if I select M-Audio Delta ASIO from the list, I noticed that the latency times get much larger on the info boxes listed below. I'm not sure if its the default device...I'll have to check that tonight once I get home.
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
Welcome!
Yes, Windows Media Player did play sound. So does my web browser. And the correct output was set as default in the control panel.
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
Ap
I think this might actually be a MIDI/triggering problem, did you have any more information on this?
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
Nevermind...seems to be an issue only with EastWest's PLAY VSTs...I'll take it up with them, unless anyone here has any suggestions?
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
Sorry for the late reply, I was gigging out of town for a couple of days.
Did you get it working reliably in Cubase?
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
No worries, I was out of town until today as well. Its working well with cubase 5 now (except I can't seem to get Cubase to recognize the EastWest PLAY VSTs...a separate issue though). PLAY standalone is the only program now I can't get audio out of. I guess I will try a clean uninstall/reinstall of all PLAY products and see if that fixes anything. Thanks for the help, I'll post my results in case anyone else runs into this particular problem.
Windows 7 64 bit
Corsair 750W
Antec 900
Maximum case fans
