Windows 7: Lenovo Z60m issue no sound (already tried work-around)
21 Mar 2010   #1
Windows7Nippon
Hi there
I downloaded the SoundMax driver version 6.xxx which was recommended HERE but I have a slight problem.
I am running Home Premium OEM for the Japanese market. Now while I can read Japanese fine the issue I've encountered is that the Device Manager set up is actually different from the US version. I eventually found screen shots of the US walk through for using Device Manager and confirmed that things are actually located in different spots on the menus and whatnot.
So I am not confident that what I'm trying to do exactly mirrors the process outlined in the above-quoted post, although it should be the same...
That being said, I managed to find a way to 'update driver', however, in the recommended file I downloaded HERE I could not find the file named ADIHdAud.inf so I was not able to specify it when updating the driver. All in all I just couldn't get the work around noted above to work for me.
Simply using setup.exe also failed, as it did not find my speakers or SoundMax equipment.
Can anyone here possible supply me with the necessary driver ADIHdAud.inf and/or point out where it is in the zip file I downloaded, and could someone possibly give me an alternative or slightly more detailed walk through for installing it?
Thanks very much
Edit: Here's a photo of what I'm talking about
If its too small to see here's the link:
http://i656.photobucket.com/albums/u...e/b048419a.png
22 Mar 2010   #2
Windows7Nippon
bump
Lenovo, windows 7 64, no sound
Hello, I see many similar threads here but no one helps me to solve an issue with sound on my desktop computer Lenovo with 64 bit windows 7 OS. In Device Manager under Sound, video and game controllers I have listed Realtek High Definition Audio and under properties of that message "This device...
Lenovo g500 Windows 7 sound does not work.
Aslam O Alaikum, Friends, I am facing very strange problem with my laptop. I have lenovo g500 with Windows 7 installed in it. I am facing trouble with sound of this system. When I starts my Machine some times sound stops working. To get sound back I used to uninstall sound drivers and...
Hardware & Devices
lenovo y460p touchpad sound and sound does not work
hello i wanted to report a problem i have on my PC regarding the sound..there is no sound without the headphones and my touchpad sound buttons do not work it has been a month already i tried downloading realtek drivers from this site it does not work again..i can only hear sound with my...
IBM z60m No sound?
Hello! After searching the forums, I can see other's with the same issue, however no fix posted? Does anyone know why my IBM z60m has no sound after a clean install of Windows 7? I had sound before? Now I have nothing, not even with external speakers or headphones. When I go to the device...
Lenovo Z60m
Okie, while I go off and search for answers, I'll pose this one,.. I installed build 7100 on my Lenovo Thinkpad Z60m last night, ran windows update, all the hardware seems to be found okay, but for some reason the audio side of things is seeing the laptop as having S/Pdif audio, which it...
Hardware & Devices
Sound problems with Lenovo
i recently upgraded to Windows 7 and it says that there is no audio playback devices installed i tried installing drivers already, troubleshooting, and uninstalling then reinstalling the driver to no avail someone please help it would be highly appreciated
