Well Build 7077 works perfectly and my surround sound!!
Bryce
10:53 PM
Raleigh, NC
Well, 7077 build works perfectly and even my surround sound. It was a stupid error on my part :(. I forgot to select the 5.1 surround sound option in the Control Panel lols.
Vista Ultimate x64, Windows 7 RC 7100Intel C2D E8400 @ 3.8ghz4x 2gb G.Skill DDR2 1600nVidia GTX260 896mb
ASUS P5Q SE PLUS
nVidia GTX260 896mb
Onboard 5.1 Surround Sound
22" Acer LCD and 19" Westinghouse LCD
1680x1050 and 1280x1024
Seagate Barracuda 7200rpm 750gb
Western Digital 500gb
Corsair H520X 520w
Antec 300
Old G15
Logitech G5
15mbps down .34mbps up
So, it might have worked in previous builds? :p
XP
XP
Yea it might of, stupid me :(
ASUS P5Q SE PLUS
nVidia GTX260 896mb
Corsair H520X 520w
Antec 300
Old G15
Logitech G5
What are you using for sound?
    W7 Ultimate x64/W10 Pro x64/W11 Pro Triple Bo...AMD Phenom II X4 975 Deneb 3.6ghz - 965 2nd r...Kingston Hyper X DDR3 1600 1.5v 16gb - Hyper ...MSI HD Radeon 5750 1gb - MSI HD Radeon 6450 o...
    Custom builds = 2
    Asus 1440x900 - HP 1600x900
    Zalman CNPS9900A
    W7 Pro x64/W11 ProAMD Deneb 3.6ghz - 965Kingston Hyper X Fury 8gbMSI HD Radeon 6450 DVI Output
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    NZXT Vulcan mini tower
    DSL 5G
ASUS P5Q SE PLUS onboard sound. It's in my system specs tab.
ASUS P5Q SE PLUS
nVidia GTX260 896mb
Corsair H520X 520w
Antec 300
Old G15
Logitech G5
The one problem with onboard is not seeing anything other then Windows own sound controls, speaker settings. Those are seen in the Control Panel>sound.
You simplyhighlight the item and then click on the configure button seen on the first tab to select the 5.1 as you test the sound output. In 7 you no longer see the advanced tab on the volume control for changing them there.
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
I've got it working already. Thanks though.
ASUS P5Q SE PLUS
nVidia GTX260 896mb
Corsair H520X 520w
Antec 300
Old G15
Logitech G5
Glad to hear you have that sorted out. At least this can be a reference at least for anyone not too familiar with the way 7 is arranged over XP, Vista.
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
