Sound out of Speakers, not headphones
cantcme99
8:21 PM
On my brand new Asus laptop, I have not been able to figure out how to get sound out of my headphones when I plug them in. On my old laptop, if I plugged in the headset, sound went there automatically. Not on the new computer. The headset I have has a USB plug. I was able to get sound out of them once- by disabling the speakers, Realtek Digital Output and Realtek HMDI Output--- if I just disable the speakers, the default goes to the Digital Output and I get no sound at all, so I had to disable everything. AND, in order to get all that back, I had to do a system restore to an earlier date because I have no idea how to get them back otherwise. Please help. :confused:
windows 7
Asus G60
windows 7
You need to select the "Speakers" as the default device if you have it set to "Digital Output" you wont get any sound at all, Go into Control Panel\Sound and rightclick on "Speakers" and select default device.
Windows 7 Ultimate x64 Service Pack 1 (Build ...Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA77...Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)ASUS nVIDIA GeForce 560
Windows 7 Ultimate x64 Service Pack 1 (Build 6.1.7601)
Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
RealTek ALC885/889A/890
ChiMei CMV CT-730D 17inch (LCD Monitor)
1280-1024 60Hertz (Ture Colour 32bit)
2x Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (AHCI)
ANTEC 750w Earthwatts
Thermaltake Shark (VA7000SWA ATX) Full Tower
Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
Labtec Media Desktop Y-SAD65
Razer DeathAdder 3G Infrared Sensor (1800DPI)
Telstra BigPond Elite Liberty ADSL2+ 24Mbps/256kbps
ASUS PCE-N13 802.11n Wireless LAN card
