Upgraded to Build 7077 - Staticy Sound now
Page 1 of 3 123 LastLast
  1. Posts : 17
    Windows 7 7201, Backtrack 4
    I upgraded (not a clean install) to 7077 today from 7048. I reinstalled the latest Realtek Driver, and my sound is staticy on files played from WMP 12.
    I had this issue before on both an upgrade and clean install of 7057, which is why I went back to 7048 among other reasons.
    Anybody have a tip, trick, or fix for this? I have tried different sound settings, some are worse than others, but there is static or skipping sound in all media files.
    Thanks in advance!
  2. Posts : 1,003
    Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
    Not a good move to upgrade. These builds are not designed for upgrades and so will not remove the previous files completely.
    I recommend you clean install. :)
  3. Posts : 2,036
    Windows 7 Professional x64
    +1 .....I tried an upgrade ONCE and that's all it took. I had sound problems too. Delayed sound and static. I did a clean install and it worked fine. That was on 7048 so....I think Romulinx is right. (or it's the easiest way to fix this and other problems too)
  4. Posts : 17
    Thanks guys for telling me what I already knew had to be done, and providing me with the push to go ahead and do it :)
    I bit the bullet, and just got finished with a clean install as well as reinstalling all my apps. Sound is crystal clear now!
  5. Posts : 1,003
    No problem. I'm glad it sorted your problem out. :)
  6. Posts : 1,402
    Good advice.
  7. Posts : 1,402
    Well done!
  8. Posts : 22
    Windows 7 (build7000) 32-bit
    Glad a Clean Install worked for you. However, I have Seven build 7000 and have Static and horrible sound issues. It Was obviously an install and not an update.
    Any tips?
  9. Posts : 918
    Windows 7 Professional, Windows Longhorn 4074
    Any tips?
    I think the torrent was slightly damaged. That, or the sound drivers for your speakers are dysfunctional or junk.
  10. Posts : 6,305
    Any tips?
    You could download the lates drivers for your sound card. As each passing week/month goes by more & more drivers are being created with support for Windows 7.
