Upgraded to Build 7077 - Staticy Sound now
  1. Posts : 1,003
    Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
    Hi AreoX,
    Did you download from Microsoft or not?
  2. Posts : 918
    Windows 7 Professional, Windows Longhorn 4074
       #12
    Romulinx2 said:
    Hi AreoX,
    If you downloaded from MS, you shouldn't have any problems. Also, you could check to see if the wire is connected properly (I thought I was having the same problem with Vista, and that was the problem).
  3. Posts : 22
    Windows 7 (build7000) 32-bit
    It wasn't a torrent. I got it directly from MS.
    All Audio drivers are up to date.
    Tried with 2 different sets of speakers, so it isn't the cord.
    The sound it makes is kind of like when you blow the Bass on speakers. Things sound normal untill some sort of bass comes on. Then it rattles.
  4. Posts : 1,003
       #14
    Check to see you haven't got a gain control for bass boost set too high?
  5. Posts : 22
       #15
    i don't. tried it on two sets of speakers and played with the tone/bass on both and i just tried it with the speakers built into my flatscreen, still problems. Maybe i'll just go buy a new sound card...
    (the one im using is an SB Live! card)
  6. Posts : 1,003
       #16
    Another thing to try.
    1/ Uninstall all the software for the card
    3/ Shutdown PC
    2/ Remove the card
    4/ Put card back in
    Windows will update the drivers, or you may have to find some?
  7. Posts : 22
       #17
    Drivers are up to date. I got this error however (see image)
    Attached Thumbnails Attached Thumbnails Upgraded to Build 7077 - Staticy Sound now-untitled.png
  8. Posts : 1,870
    MS Windows 7 Professional 64-bit SP1
       #18
    Dont you have onboard sound?? I would use that, than the creative sound card......
    Dont bother with creative products
  9. Posts : 918
       #19
    You could do what the box says. Windows knows all...
  10. Posts : 12,364
    8 Pro x64
       #20
    There's your problem
    Perhaps this may help:
    SoundBlaster Live! (EMU10K1) terrible sound?!
