Windows 7: sound problem
24 Mar 2010   #1
trogne
sound problem
Hello,
I have a sound problem on my HP Pavillon desktop (windows 7).
Everytime, after some hours of use, I hear sound clicks&pops.
I restart, and the problem is back after some hours.
When sound clicks&pops occurs, I see abnormal CPU usage in task manager.
Like going back and forth from around 25% to around 65%.
HP support can't help (they say to do a system restore... they say that for every problem).
Can someone help? Another forum I should post?
Thank you,
Patrick
24 Mar 2010   #2
win7clutz
Windows 7 Ultimate (64)
Have you done a system restore? Please go to your sevenforums profile and complete your system specs...
This sounds like the old days when certain devices were attempting to share addresses and irq's, shouldn't be happening today...
24 Mar 2010   #3
Aphelion
Windows 7 Home Premium
Patrick,
Because of the current state of Windows 7 audio drivers this is someaht of a common problem. One thing that always causes this is if the system goes into "Sleep Mode". After coming out of sleep the audio will be corrupted. If this is the problem, best to disable sleep mode.
Check and see which process is using the CPU.
In task manager select the "Processes" tab.
Then select the "Show Processes From All Users" checkbox. You should be able to zero in on the process that's causing the problem.
Ap
24 Mar 2010   #4
whs
Microsoft MVP
When the problem occurs, run this program. Everything should be green. If you have a lot of red, you may have some driver problem.
25 Mar 2010   #5
trogne
Hello,
Thanks for all the replies.
Good idea for sleep mode! It might be that!
By disabling sleep mode, you mean that I should use hibernate when I'm leaving the pc? Or simply always shutdown?
I'll do latency checks back from work.
Patrick
25 Mar 2010   #6
trogne
I'm at work.
I think I'm using Hibernate instead of Sleep mode.
Can this problem occurs also with Hibernate mode?
So, if yes, I should always shut down instead of hibernate and sleep?
25 Mar 2010   #7
Aphelion
Quote   Quote: Originally Posted by trogne View Post
I'm at work.
I'm not sure, I disable Hibernate first thing after installing....
I believe Hibernate is sleep but with the computer's memory saved as file on the hard drive.
I know that my onboard sound will have clicks, skips...etc if I let the computer go into sleep mode so I would think Hibernate would cause the same problems.
I'm fairly sure this is either an audio driver problem, or a problem located in the BIOS.
Instead I set my drives and monitor to powerdown in 20 minutes.
It's easy to test, disable Sleep/Hibernate for a day.
Ap
25 Mar 2010   #8
trogne
Thanks, I'll try that.
I'm sure that is the problem.
When you say "disable Sleep/Hibernate", you mean to just not go to Sleep/Hibernate mode? If not, how can disable Sleep/Hibernate?
25 Mar 2010   #9
Aphelion
All the settings (except Hibernate) can be accessed from:
Control Panel/Power Options
Then select "Change Plan Settings".... for the good stuff select "Change Advanced Power Settings".
Since you're on a desktop, under the advanced section set Min/Max processor settings to 100%.
To turn Hibernate off, open a Command Shell and type:
powercfg /HIBERNATE off
Then hit Return or Enter. To turn it back on.. same command with on instead of off.
Ap
p.s.
Does anyone know of a way to access hibernate from the Windows interface?
05 Apr 2010   #10
trogne
Hello,
No more sound problem since I don't use hibernate or sleep.
But might this be fixed with a windows update someday?
Is there something I can try to fix it?
Thanks,
Patrick
 sound problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound problem
Hi all, I had this problem with my laptop sound randomly disappears and it comes back after a while like 15 min or so.I have Realtek HD Audio Driver installed.Is it problem with my driver? Can anyone help me with this? i am despreate !!!
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
Sound problem serious
I have a custom built pc with an asus psk motherboard, I'm using the built in sound card in that for my sound. When i had vista i installed all the drivers etc and my sound still didnt work it said my sound driver was a realtek hd sound driver which was a problem because my speakers and headphones...
