please HELP me to get sound Drivers!!!
  1. Posts : 525
    Window 7 Ultimate 32bit
    I am working on a Asus PC and all that I could get on the motherboard is that it is an Asus Mozart 1-2, can someone please get me sound drivers for this motherboard please this is urgent.
    Thanks a lot guys.
  2. Posts : 13,354
    Windows 7 Professional x64
    I'm having trouble finding drivers with that amount of data. If you want, you can download Speccy (see my sig) and post a bit more specs.
    You can also use a driver updating program such as Driver Easy to scan for updated drivers for all of your hardware.
  3. Posts : 525
    this is not my PC and I can't get INTERNET on it, he motherboard is a Asus P4SGL-VM. Please see if you can get me a link of a driver, it is 487 socket.
  4. Posts : 13,354
    The best I can find is the XP drivers: http://www.google.com/url?sa=t&sourc...-D6-M3YDFxI8Lw
    You may find they will install in Compatibility Mode, or they might not work at all.
  5. Posts : 525
    it is for XP mate
  6. Posts : 13,354
    Sorry, I assumed it was Windows 7.
    That's good, those drivers should work great then!
  7. Posts : 525
    I have that one mate and I installed it but there is stil no sound, and the volume is open. What could then be the problem if the driver is installed?
  8. Posts : 525
    No it does't work great mate, I am in deep sh#t now. The download size is only 126 (KBytes) and it is not a exe just files, so what I did was I extract the files and when to device manger and said advanced location and it transfered all the files and it said device is working perfect. So my qustion is it isn't the wat is the problem coz I formatted the PC
  9. Posts : 908
    Windows 7 Home Premium
    What output jack are the speakers plugged into, you do have speakers, correct? Use rthe light green jack for speakers.
    Ap
  10. Posts : 525
    Ap
    Yes I did bro not a sound coming out
