Help with static sound
monster528
6:25 AM
i have a 5.1 surround sound system and for some reason all the sound coming out of the speakers is mixed in with static noise.
recently i completely formatted my hard drive (you can check the link here)
i reinstalled my sound driver (Realtek) but i still have the same issue. any help?
my sound system is the x-540 logitech
Windows 7 64 BitIntel Core i5 4670K 3.4GHz Socket LGA 11508GBATI HD 6950
Windows 7 64 Bit
MSI Z87-G41 PC Mate Socket LGA 1150 ATX Intel Motherboard
8GB
ATI HD 6950
ASUS GTX760-DC2OC-2GD5
1TB
Is the driver installed correctly and working in device manager? Is it listed? does it have a yellow triangle on it?
Have yoou tried different cables?
Made sure everything is tight and not frayed?
etc
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
i wish it was that simple.
ive already went through all these steps before i posted on here. also ive tried using different speakers.
so far nothing different
Windows 7 64 Bit
8GB
ATI HD 6950
1TB
heres some more info: when i change the quality of the sound (in the sound options) the static/cracking sound changes slightly. more drastic change between the highest and lowest quality.
i dont know if that helps, but thats what i notice
Windows 7 64 Bit
8GB
ATI HD 6950
1TB
alright guys i FINALLY GOT A SOLUTION.
i emailed realtek and they sent me a beta driver to install. i guess the problem was:
The root cause problem was SiS chipset on the computer . The SiS chipset has some audio problem in Windows 7 .
Windows 7 64 Bit
8GB
ATI HD 6950
1TB
