- Local time
- 10:39 PM
- Messages
- 32
Hi people
I posted a thread before but got no replies, I didn't know how to remove it so posted this one with more information.
My System is:
i7 Processor
6GB DDR3 Ram
ATI Radeon HD 5800 series
DFI LanParty JR X58 T3H6 Motherboard
I've recently installed windows 7 64bit on it and I'm trying to setup up my surround sound via optical cable to my amplifier which all was working fine when I had XP running (no problems at all and sound was perfect)
Since installing Win 7 I've only had headache trying to get the sound working how it was before, and I'm now at the point where I honestly dont know what to do.
I've installed the latest Realtek Audio driver R2.46 but to no avail I dont even get the option to select 5.1 in the audio settings or Realtek HD audio Manager! Which I did before when I was running Win 7 on my old system just after upgrading from XP, but even though I could select it on my old system (running Win 7) I still didnt get true surround as i had to force it through the settings ie: ticking the room option etc.
Which resulted in really poor sound quality, hence why I pretty much bought a whole new system (spec above) thinking this would sort it out. WRONG!
I'm now worse off as I'm not seeing any option for 5.1 at all even though it says the HD driver is installed, I tried letting Windows install the driver automatically but no joy there either! Which makes me think this problem stems from windows 7 itself?
I searched some other forums also the web and have seen countless people with the same problem so surely it is?
More to the point has anybody out there solved this problem? If so how?
And PLEASE if anybody can help me I will be truely grateful as right about now my head feels like it's going to explode!!
My System is:
i7 Processor
6GB DDR3 Ram
Windows 7 Home PremiumIntel Core i7 CPU 920 @ 2.67GHz 2.79GHz6 GB DDR3ATI Radeon HD5800 Series
- Windows 7 Home Premium
- Intel Core i7 CPU 920 @ 2.67GHz 2.79GHz
- Motherboard
- LanParty JR X58T3H6
- 6 GB DDR3
- Graphics Card(s)
- ATI Radeon HD5800 Series
