Windows 7: Mic volume way too low! Help :(
03 Apr 2010   #1
Nox
Windows 7 64
Just upgraded to Windows 7 and now my mic volume is so low I have to struggle to hear anything I personally record (with windows "sound recorder").
The volume is turned up to max (100) in the levels tab, I don't go up beyond +10 microphone boost because I sound distorted and robo-like.
In the advanced tab for the microphone I have the "allow applications to take exclusive control of this device" unchecked.
In the communications tab of the sound control, I have "do nothing" selected. (accessible by selecting "volume mixer" then selecting "system sounds")
Can anyone help me out with this? The only way I can hear anything is if I turn my headphones up to max, and even then it's slightly over a whisper. I know it's not my headset/mic as it worked perfectly fine in Vista, and it works as it should on other computers. I'm out of ideas as to what I can do to remedy this issue, can anyone help?
04 Apr 2010   #2
Airbot
You'll have to post what exact sound card, or onboard sound you are using so the users can help you out. And preferably, the rest of your system specifications.
Does Deleting USB HardDrive(Volume)Revert It To Inactive Volume
Have an external USB hard drive caddy with a naked Raptor drive sitting in it which has one partition that is the entire capacity of the Raptor drive...this is an 'active' volume. 1. Can someone tell me if I delete the volume under Computer Management>Disk Management>Delete Volume will this...
Hardware & Devices
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Volume not loud enough - how do I bypass volume limit?
I like to listen to music loudly sometimes. I have both the volume mixer and my application's volume set to maximum levels, but it's not loud enough for my liking. Is there any way to increase the maximum sound volume in Win7?
Soft Recording volume with Blue Yeti, increasing volume distorts audio
So I have a Blue Yeti, and I'm an online animator/voice actor. Whenever I record audio on my Blue Yeti (OR any other mic) I record about 4-6 inches from the mic, and turn the gain down enough that the audio doesn't peak as I yell or whatever. This is what you're supposed to do if you don't want...
How to increase max volume and decrease minimum volume
I use W7's volume control for the studio monitors I use. It's not practical to use the knob on the monitors since it is located in the back. The max volume (100%) in W7 is not loud enough while the minimum volume (0%) still makes sound when Id like it to be mute if it's at 0% How can this be...
Extremely low volume on headphones but high volume on speakers
y0 I got this other problem i really hate. The most. Please jonathan_king, zigzag reply please. I beg you, i got this problem that i plug in my headphones and its extremely low volume. It use to work fine, but now nope. I tried the jacks on the front, back and my monitor. Please help me.
