A Different Surround Sound problem
A few days ago I had to replace my motherboard. The PCIe video card from the old system is a Radeon 4350 with HDMI (7.1 capable) which I consider to be better than the on-board Radeon 2100 in the new mobo (it's HDMI only supports 2-channel). I have the 2100 disabled in the device manager.
If i go to Control Panel/Sounds, all 6 channels test perfectly on the Radeon 4350! But then I go to MediaCenter settings and tell it I have a 5.1 audio and it accepts it, but when MediaCenter tests the speakers or plays back a show recorded in 5.1, all sound comes out of just the front L & R speakers attached to my HDMI-switching receiver.
I'm going to see if it makes any difference to disable the audio on both HDMI's and use the optical S/PDIF instead.
