Using an External Sound card
DarkDavil
Avatar thanks to BFK :D
Power User
10:29 AM
Illinois...India?
Hello all, as my internal laptop sound card doesn't support SPDIF out - i've decided to go with an external sound card and through the external sound card - hook it to my receiver for 5.1/7.1 sound.
My question is how is it that i would connect my external sound card to my receiver.
Say i was to get this
One
Which cable would i use to hook that to my receiver?
And would that ensure that i'm getting 5.1 surround sound on my surround sound system?
Is that a good external card?
And to top it all off - could anyone recommend a good external sound card that supports 7.1 out?(I won't mind with a 5.1, but my system has 10 speakers - so i support 7.1 and beyond!)
7 x64/ Back-Track 4Intel Core 2 Duo CPU 8300@ 2.4 Ghz4096 MB DDR2Nvidia 8400M GS
HP dv6000t CTO Entertainment Lappy |My Desktop @ Bottom
7 x64/ Back-Track 4
HP's Own
4096 MB DDR2
Nvidia 8400M GS
Altec Lansing (The usual on Laptops )
Laptop Screen. 17' Wide.
1280 x 800
150 GB HDD.
2 External Fans, Undervolted, Coolant
Norm. Cheap Random Keyboard
Norm. Cheap Random Mouse
This is my Homemade Desktop :)
HDD: Western Digital Caviar Blue 320GB 16MB 7200RPM SATA2
And more to come in a bit! :D
I'd recommend the Sound Blaster X-FI 5.1 USB.
Granted, it's not 7.1, but it's a really good external sound card. Furthermore, you're not going to find many external sound cards that are 7.1 unless you look into actual professional sound gear. Not to mention, most of the external sound cards that are labeled "7.1" are actually virtual 7.1...
Sound Blaster X-Fi Surround 5.1 | Creative Labs Online Store
How it works:
You connect the sound card to the laptop via USB.
Connect All Sound Cables to Subwoofer in my case (Left, Right, Rear, Center/Sub)
Connect Subwoofer to all Speakers
Package comes w/ a 2 prong male RGB to female 3.5mm converter so you can connect a 3.5mm speaker cable to the Left/Right connections.
In the case of the SB X-Fi USB 5.1, you should be able to connect via the optical cable and/or the regular cables for 5.1 sound
I've been using this card for a year now and I love it. It sounds much better than my built in sound. Currently I've got it supplying sound to a set of Logitech X-540 speakers. I also have my Sennheiser PC 151 headphones hooked up. One thing I like about this sound card is the fact that when I plug in my headphone's jack it automatically turns off the output to the speakers. It also automatically turns them back on when I unplug. You can leave the mic jack plugged in all the time, these jacks aren't in the picture below, they're on the side [Headphones, Mic In, Line In]
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
How it works:
Awsome man! +Rep for sure - I'll use the optical cable most-likley. :) Great info :D
7 x64/ Back-Track 4
HP's Own
4096 MB DDR2
Nvidia 8400M GS
1280 x 800
150 GB HDD.
I just installed mine and the volume knob doesn't do anything. Have you tried using the volume knob? Does it increase or decrease the sound, the way you have it set up?
Windows 7 Home Premium
