Trying to get my audio to work!
Krispy1
Power User
2:39 AM
Toronto
i installed 7 on this older pc i have that was made with some different parts. im trying to get audio on this but i havnt had any luck.
here is the pcs specs.
windows7 32bit
p4 2.4ghz
512ram
and here is the motherboard info:
Manufacturer: ASUSTeK Computer INC.
Model: P4T533
Version: System Version
Chipset vendor: Intel
Chipset model: i850E
Chipset revision: A3
Southbridge vendor: Intel
Southbridge model: 82801BA (ICH2)
Southbridge revision: 04
BIOS
Brand: Award Software, Inc.
Version: ASUS P4T533 ACPI BIOS Revision 1006
Date: 03/14/2003
are there any generic audio drivers that would work.
anybody can help me thank you
Windows 7 Ultimate 64bitAMD Phenom II X4 945 @3.0ghz4gb kingston hyperX1gb Radeon HD 5670
Asrock
4gb kingston hyperX
1gb Radeon HD 5670
Hi and welcome to seven forums krispy1, do you have realtek HD audio software on your pc
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
no i dont, just installed 7 on this pc today.
Asrock
4gb kingston hyperX
1gb Radeon HD 5670
ok ,i ask only as i have and have a little info on that , try this control panel/ troubleshooting under hardware and sound there is a troubleshoot audio playback link give that a whirl let us know how you get on
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
trouble shooting doesnt help
Asrock
4gb kingston hyperX
1gb Radeon HD 5670
windows7 32bit
p4 2.4ghz
512ram
Model: P4T533
Is it an Asus P4T533-C (is there a letter after the 533)
The first or second search in Google shows that this board has a Realtek AL650 audio chipset.
I thought Windows 7 supports that.
Is the microsoft speaker icon in the Task Bar?
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
i solved the problem. i went to the asus site. had to do some digging then i found they still had driver support but only for 95,98,2000,xp. i knew that for some reason windows 2000 drivers sometimes work better with 7 with old hardware then xp drivers(i dont know why) so i downloaded the motherboard sound driver. then went threw device manager>update drivers then chose the drivers which i had placed in a folder on the desktop. windows 7 recognized the driver and installed the windows 2000 driver successfully and now the audio works
Asrock
4gb kingston hyperX
1gb Radeon HD 5670
good news :)
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
