Skype soundcard detection issues
  1. Posts : 1
    win 7
    Hi all,
    Hope someone out there can help me. I have recently updated to Win 7 and well it's fantastic for me so far but I have a little problem. I live away from home and a regular user of Skype Im having a problem making calls. Everything else on the software is ok, sms works, I dont use a web cam so I dont know if that works. When trying to make a call it connects but the ringing sound comes from the speakers not my usb phone. I have a RED mic icon on status.
    As to the other sound on the system its all ok, no problems with music, movies, Games etc
    I have checked around a little on some forums on the web but so far I havent found many similar threads to my problem.
    thanks
  2. Posts : 6,879
    Win 7 Ultimate x64
    bradreid78, welcome to the forums.
    If you haven't yet have a look in the Windows Sound properties and make sure your USB headset is set as the default communication device for both playback and recording.
  3. Posts : 141
    windows 8.1 pro
    had the same problem.
    go to. tools, options, show advanced options.
    move up and down to default tthe correct option.
  4. Posts : 35
    Windows7
    If you haven't already fixed this problem try the steps below. They might be able to fix your problem!
    Skype:
    Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
    You can also tick the ring pc speaker check box as this is a good backup to alert you even
    if the main speakers are off or turned down.
    Windows:
    Start-->Control panel-->Sound and Audio devices
    On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
    Your installed audio device must be present there.
    If not, reinstall audio devices.
    I hope this helps!
    Brett M,
    Windows Outreach Team
