cracking sound ( not due to speaker set )
Uncle Seamus
11:02 PM
Belgium (Flanders)
the sound coming out of my speaker set (creative I-trigue 3330) is cracking. Now, I have connected my speaker set to my mp3-player and everything works just fine. When I connect my headphone to the pc, I again experience bad sound.
Conclusion: my speaker set is fine, my pc isn't.
Does anyone know what can be the cause of this issue?
Thanks for your time
Windows Seven Home Premium 64-bitIntel Quad Core Q9400 (2.67 GHz)Corsair 2 X 2GB RAMAsus1GB D3 X ENGTX280 OC/HTDI R (Nvidia GeFor...
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Asus1GB D3 X ENGTX280 OC/HTDI R (Nvidia GeForce GTX 280)
Onboard
Samsung SyncMaster T220
1680 x1050
Seagate 500 GB SAT2 3500320AS
Coolermaster Real Power M 1000W ATX 2
Chieftec Giga GX-01B ATX
Fan-based (no water cooling)
Logitech Clssic Keyboard 200
Razer Lachesis
Sound: Creative I-Trigue 3330
Sounds like a driver issue to me.
Go to this website and place your motherboard model in the search box. Once you choose your OS in the popup you'll be able to download your audio drivers.
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
updated the driver but the sound isn't better
could this be DirectX related? I believe I did a re-install before problems first occurred.
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
This is a rough one, crackling can be caused by so many different circumstances.
It could be a wireless driver conflicting, or the network adapter (ethernet), or even software using up abnormal amount of CPU.
I see you have an nVidea graphics card... is there a process/program running in the background called "powermizer"? A lot of stuff nVidea runs in the background is heavy handed.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
powermizer isn't running as far as I know...I also ran everest to see if my cpu was the cause of the problem, but he seems to be fine
stress test didn't show anything unusual, as far as cpu usage or temperature goes
I do have wireless Internet, but I didn't make recent changes to the adapter
I tried another reinstall of directX but it didn't help
I still believe directX may have something to do with this, since problems started very soon after the reinstall
thanks for looking into it
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
powermizer isn't running as far as I know...I also ran everest to see if my cpu was the cause of the problem, but he seems to be fine stress test didn't show anything unusual, as far as cpu usage or temperature goes
I doubt if it's Direct X, but anything is possible.
If you right click on the taskbar and select "Start Task Manager", select the Processes tab and you will get a list of (depending on the check box) all processes running or processes associated with your user name login.
Also look under "Administrative Tools" and select "Services" often there are services running that have a negative effects on audio, generally associated with the graphics card.
Also, if you would like to test and see if any devices are causing a problem, open device manager and disable Wireless, or the Network adapter, they're easy enough to re-enable.
Was anything different about the most recent re-install, did you download new drivers for any devices?
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
I got a stupid question. Have you checked your headphones on another PC? Perhaps the wiring in them is loose. Sometimes the plugin cable gets worn out, and they begin to fail.
Windows 7 Enterprise x64AMD Athlon 64X2 Dual Core 3800+OCZ Platinum Dual Channel - 4x1GbNVIDIA GeForce 8800 GT PCI Express x16
NVIDIA
GeForce 6100-M9
Creative Audigy Sound Blaster Extreme PCI
Compaq 7500
1024x768
C: Seagate ST3250318AS SataII - 250Gb
D: Seagate ST3500418AS SataII - 500Gb
OCZ 600w Dual 12v Rails
Thermaltake
OCZ Heatsinks, Fans, and Thermal Paste on CPU & Chipsets
Radio Shack PS2
Cable
Dual Pioneer DVD/RW optical drives. LG CD/RW optical drive.
I have disabled my wireless network adapter but the crackling remained
I also checked device manager and two processes seem a little odd:
"aeadisrv.exe" and "smax4pnp.exe"
besides that: I recently updated the driver for my gtx 280 graphics card
@madmaxdata: I have connected my speaker set to my mp3-player with perfect sound as a result
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
Did you have the crackling audio before the graphics card update?
From the web...
"aeadisrv.exe"
"Andrea ADI Filters Service. Service installed by the SoundMAX SupremeFX drivers for SupremeFX based sound cards, or for SupremeFX onboard sound (many ASUS motherboards, for example), fitted with Andrea Electronics noise filtering technology. The only role of this service is to aid the reduction of background noise when you use a microphone. Nothing else depends on this service.
There have been so many problems with this service since its introduction at the beginning of July 2007, and there are still so many problems at the time of writing, 18-Aug-2008, that the only recommendation we can make is to disable this service immediately.
And.....
Smax4pnp.exe is a system process that is part of the SoundMAX software program. It is not necessary for sound to work on your computer but is mainly used to run or add components to the SoundMAX software program. Smax4pnp.exe is not a malicious spyware of malware and generally runs automatically at startup and can be removed safely without affecting the sound on your computer. Unless you use the SoundMAX audio program, it serves no use on your computer.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
It may be an audio driver conflict. You HAVE tried removing the drivers from Control Panel....right?
I have an Asus P5B Deluxe mb with onboard audio chipset. I had windows 7 install it's default drivers for what it detected. In other words, you don't always need to download and install your mb audio chipset or soundcard drivers. Often times, just letting Windows 7 select the driver is sometimes better than downloading and installing specific drivers. I did NOT have to install the SoundMax drivers to have my windows play sounds fine. Windows own set did fine. In fact, I had some problems with no sound on Youtbue videos. I thought it was Google Chromes fault. It wasn't flash or quicktimes fault.
Here's a major tip, if no YouTube video sounds, uninstall and reinstall audio drivers! It sounds like it wouldn't solve it, but it does for some wierd reason. Many many have found this worked.
I think was a codec conflict as to why Youtube sounds didn't play. It may be with you too.
Windows 7 Premium
Windows 7 Premium
First thing to check is if there is any CPU throttling set in the bios. It goes by different names, depending on motherboard...aka..."Cool n Quiet". Disable it to test. Throttling could also be happening if you are running preloaded software from the manufacturer at Windows start. Check the system tray for something like that, if it exists.
Win7
Win7
Check for DPC Latency (google it, it will point you to dpclat.exe utility, use it to measure your system's DPC latency). I suspect it's DPC latency problem...
zzz2496
Windows7 Ultimate 64bitIntel Core 2 Quad Q6600DDR2 Adata 4GBNvidia GeForce GTX 285 1024 and Nvidia GeForc...
Abit IN9-32X-MMAX
DDR2 Adata 4GB
Nvidia GeForce GTX 285 1024 and Nvidia GeForce 8800GT 512
Asus Xonar HDAV 1.3
Dell 2407WFP and BenQ 2400v and Philips 150v3
3840x1200 and 1024x768
2 WDC 1TB
1 WDC 1.5TB
1 WDC 640GB
1 WDC 320GB
1 Seagate 200GB
Corsair TX 850W
Cooler Master HAF932
Arctic Cooling Freezer Extreme and plenty of fans...
MicrosoftNaturalKeyboard 4000/Apple Alu keyboard/Dinovo mini
Logitech G5/MarbleMouseTrackball/PerformanceMX/SpacePilotPRO
1.5Mbps down/384Kbps up
APC SURT 1000XL
Logitech Z-560
Wiimote
Mikrotik Router
Linksys (now Cisco) SD2008 8 port Gigabit switch
Linksys WRT54G (acting as AP)
Apple wireless Aluminium keyboard
Apple Magic Mouse
Xbox360 wired controller
first of all, thanks for all the replies...really appreciate it
I have tried out everything, but nothing seems to work
I'm going to roll back my video driver, but the thing is I was told - here on sevenforums - to update that driver after a recent BSOD
so in a way I hope the crackling remains even after the rollback, otherwise I have to choose between "something that might be music" or an unstable pc
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
no luck with the nvidia driver
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
How far back did you go?
I had to take mine back into the 160 series (they're currently at 190 something) to get one that would work... Nvidia admits they're having some driver problems of late and have older versions available on their website... but don't just go back a week or two... go back at least a couple of months...
Also... if your driver is installing that silly 3D video muppingsnarf (PhysX) you might like the results of uninstalling it... It can be removed separately in control panel.
XP Pro SP3 X86 / Win7 Pro X86Amd 64 x2 4200 (2.4ghz)Kingston DDR2 800 2gbNvidia GF-8400
Homebrew
Asus M2N-MX SE Plus
Nvidia GF-8400
Realtek on Motherboard
Acer x-193bw
1440 x 900
Western Digital 500g
350watt In-Win
In-Win
Air
yes
yes
5mpbs
Also ASRock ION 330 as HTPC (on XP).
Acer Aspire as GP netbook (on XP).
I ran dpclat.exe and it showed some drivers might cause audio drop-outs
I'm going to disable some of them one at a time and see how it goes
hope this was the golden tip :-)
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
It's not the golden tip, though I hope that it is...
By using dpclat.exe, you can narrow down the culprit... Most of the time, it's network controller driver that's sharing IRQ with some high performance device (another network controller or a display card) OR network controller sharing IRQ with your sound card...
zzz2496
Edit: maybe you can try this: use "Wave" as your audio output device under your music/mp3 player. I previously use DirectSound in iTunes and it crackles like mad when I scroll up/down in Firefox, moving the output to Wave seem to fix the problem.
Abit IN9-32X-MMAX
DDR2 Adata 4GB
Asus Xonar HDAV 1.3
2 WDC 1TB
1 WDC 1.5TB
1 WDC 640GB
1 WDC 320GB
1 Seagate 200GB
Corsair TX 850W
APC SURT 1000XL
Logitech Z-560
Wiimote
Mikrotik Router
Apple Magic Mouse
I'm sorry that it took me this long to find out that my wireless internet adapter is indeed the culprit
I just wasn't patient enough before while testing the different drivers
now do I have to delete and reinstall the driver, or is there more to it?
Alternate
Asus P5Q Deluxe
Corsair 2 X 2GB RAM
Onboard
1680 x1050
Razer Lachesis
I just wanted to say Thank God I found this thread. I spent nearly 10 hours uninstalling and installing different drivers for different things before figuring out what it was thanks to dpclat.exe. A program I use to identify hardware called siw.exe was what was causing it for me.
Thanks guys!
Microsoft Windows 7 Ultimate 6.1.7600.16385 x86AMD Turion 64 X2 Mobile TL-58Micron DDR2 (PC2-5300) 2048MBNVIDIA GeForce 7150M / nForce 630M
HP Pavilion dv9627cl
Quanta 30D1 v85.26
High Definition Audio Device
JW199D HannsG 19.1", HP LP171WP4-TLB1 17.2"
Seagate 120GB ST9120822AS
Western Digital 80GB WDC WD800BEVS-60RST0
Western Digital 80GB WDC WD800BEVS-00RST0
Western Digital 80GB WDC WD800BB-75JHC0
Western Digital 320GB WDC WD3200BMVS-11F9S0
Western Digital 500GB 500KS External
HP Laptop Keyboard
Logitech V220 Cordless Optical Mouse
6MB Down; 75KBs Up
If you can, move the device off what current slot it's on, say you plug it to PCIe slot 3, move it to another PCIe slot... I hope it can remedy it... OR you can try my other suggestion, use "Wave" as audio device...
zzz2496
Abit IN9-32X-MMAX
DDR2 Adata 4GB
Asus Xonar HDAV 1.3
2 WDC 1TB
1 WDC 1.5TB
1 WDC 640GB
1 WDC 320GB
1 Seagate 200GB
Corsair TX 850W
APC SURT 1000XL
Logitech Z-560
Wiimote
Mikrotik Router
Apple Magic Mouse
