2 sound cards but not really
TheCase
6:58 AM
[SOLVED] 2 sound cards but not really
Today I moved my audio card to the bottom slot away from the GPU. I come back onto windows and see screen shot it says 2 infront of the audio card name why, I only have one. I cannot here anything in Itunes, I can hear some YouTube videos and some videos
any ideas
Windows 7Intel i7 920NVida GTX 275
Intel i7 920
NVida GTX 275
Samsung 2333SW
This is because it is the second installation of the same video card. I have the same label on my SB X-FI USB 5.1 card. It's nothing to worry about.
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
Well I can only hear certain sounds the rest are just really bassy banging sounds its really odd
Intel i7 920
NVida GTX 275
Samsung 2333SW
Uninstall the device drivers, then reinstall the drivers. Then see what happens.
Edit: also this may sound very stupid, but once I plugged the speakers into the wrong ports on my soundcard, and got exactly that, although I doubt you just did that..
Windows 7 Professional x64Intel core 2 quad Q6600 [email protected]4GB 800mhz Kingston DDr2 (wants better..)ASUS ATI HD5770 1GB(Gddr5) OC 900Mhz + 1300Mh...
Eloi and his Kitchen Table
Asrock Glan 4core-1600 (sucks)
ASUS ATI HD5770 1GB(Gddr5) OC 900Mhz + 1300Mhz (Great)
Creative Soundblaster Audigy SE 7.1 (Wouldn't recommend)
24inch Samsung Syncmaster P2450H (Kickass)
Hitachi 500gb 7600RPM SATAII 32mb
Unknown DVD drive, its haunted.
320GB Hitachi (Philips external)
1TB Stor-e alu.
2x 500GB on Raid server downstairs. (Usually just hosts games and stuff, but its a "Guest" Pc too)
600W, unknown make yet decent performance
Unknown (Cheap thing, replacing)
Zalman9700LED + 1 High speed 1000-3200rpm 120mm <-- Great.
Saitek 3 Eclipse <-- pretty cool..
Logitech G500 (ex lachesis owner)
1MB/s down 100KBs up
Server downstairs is an AMD Phenom X3 705E @ 2.8GHz with a mini ninja scythe cooler.
Ive tried a resinstall, doesnt do anything. Im using headphones and speakers so Im sure everything is plugged in the right place lol :p
Its odd I can some perfect sound though
Intel i7 920
NVida GTX 275
Samsung 2333SW
I properly done something even more stupid. I had the speakers set up for 7.1 thats why it would come out all bassy its all ok now lol
Intel i7 920
NVida GTX 275
Samsung 2333SW
