Cracking / Popping Sound
ahstanford
7:29 PM
Hello everyone,
I've been noticing a "popping" or "cracking" noise coming from my speakers/headphones.
The first I noticed it was during a movie, and I assumed it was the movie's audio - but since then I have been hearing it during music and other movies and from both speakers and headphones.
I'm at a bit of a loss as to what could be causing it...
Any help would be appreciated.
Alex
Windows 7 Home PremiumIntel Pentium Dual E5400 @ 2.7Ghz6GB DDR3Onboard Video
Asus Essentio CM5571-BR003
6GB DDR3
Onboard Video
24" Asus LCD
Windows 8 ProIntel Centrino Dual Core P7450 2.13GHz4gbATI Mobility Raedon HD3650
Toshiba P300
Windows 8 Pro
4gb
Toshiba MK3252GSX ATA
Wish it were faster
I just ran that DPC Latency tool - and it's reading VERY high.... red bars all the way across the screen. About 30,000 current latency.
I disabled the only listed Network Adapter from Device Manager and the latency instantly dropped in to the green (was off the top of the screen red before that).
So, I think I've identified the problem as the ethernet controller - but what do I do?
6GB DDR3
Onboard Video
24" Asus LCD
Have you checked for an updated driver?
Toshiba P300
Windows 8 Pro
4gb
Wish it were faster
I clicked "Update Driver Software.." from the right-click menu in Device Manager and Windows says it is up to date.
I did a quick search to find the Atheros website (manufacturer of my network card) but could not find any drivers on their site.
6GB DDR3
Onboard Video
24" Asus LCD
What is the model of your network card?
Toshiba P300
Windows 8 Pro
4gb
Wish it were faster
6GB DDR3
Onboard Video
24" Asus LCD
ASUSTeK Computer Inc.-Support-
There is an Asus auto detect feature on this page that should steer you towards your drivers.
There is no guarantee an updated driver will resolve the latency issue....but it's a good place to start since you narrowed down the cause. I would also check to see if there are updated sound card drivers as well.
Toshiba P300
Windows 8 Pro
4gb
Wish it were faster
Thanks!
A reinstall of the drivers has my latency in the green.
6GB DDR3
Onboard Video
24" Asus LCD
You're welcome!
Glad to hear everything is sorted out for you.
Can you mark the thread as solved so others that are experiencing similar problems can use this as reference?
Toshiba P300
Windows 8 Pro
4gb
Wish it were faster
Ah, drivers! They fix so many issues :) - Glad you found a solution! Here is more about solving sound issues if you ever need it (fingers crossed that you won't!): Tips for fixing common sound problems.
And, yes, please mark this as solved so others can benefit from the solution here!
Cheers,
Cassandra
Microsoft Windows Outreach
Windows 7 Professional 64-bitPentium(R) Dual-Core CPU E5300 @260GHz
HP/p6207c
RealTek High Def Audio
HP 2159m
1920 x 1080 x 60
HP M/N: M-U0009-HP1
Broadband
