White noise on left speakers/left side of headphone
Conan Troutman
5:31 AM
There's this annoying white noise on my left speakers(Logitech X-540 Speakerset), though I think it's not my speakers that are causing it, but something else, because when I connect my iPod to my speakers there's no white noise.
So I was wondering if anyone could tell me how to get rid of this noise
Windows 7 Ultimate(64-bit)AMD Phenom(tm) II X4 955 Processor, MMX, 3DNo...4096MB RAMATI Radeon HD 4870
AMD Phenom(tm) II X4 955 Processor, MMX, 3DNow (4 CPUs), ~1.
Gigabyte Ultra Durable Motherboard GA-MA790GP-UD4H
4096MB RAM
ATI Radeon HD 4870
Realtek HD Audio output
Acer P203W 20"W LCD Monitor 1680x1050
1 TB+1,5 TB External
Silencer 750 Quad
Antec 300 Versatile Mini Tower
2 Fans
Sounds like either a driver malfunction or more likely a failing sound card. Most of the stuff below (Windows & Programs) wouldn't likely be causing problems. I'd be willing to bet it's a hardware problem (due to it only being one side).
Figure Out What's Failing
If you're using a secondary sound card
*** i.e. you have a second built in one on your motherboard, enable that.
If you still hear the sound on a different card, then it's something within Windows and not a problem w/ hardware.
If you don't hear the sound, then it's something w/ drivers or your hardware.
If you don't have an extra sound card, see if you can find/buy one :)
Replace Drivers
Download & Install a Program like Guru's Driver Sweeper
Uninstall your sound drivers w/ Driver Sweeper
Reboot
Download and install the latest drivers for your sound card.
Reboot​
If the sound is still there and you couldn't test a secondary card you're likely dealing with either a hardware failure (most likely with sound only happening in one speaker) or something in Windows failing.
Repair Windows
If you want to try to fix windows, you can do the following:
Run an elevated Command Prompt and run this command:
sfc /scannow
Peform a system restore
Perform a repair install.​
Test to see if a program is causing the problem
Type msconfig into start menu search and hit Enter
Go to the startup tab and disable everything.
Restart computer
Do you still hear the sound?
Yes -- Not a program
No -- A program is likely causing the problem.​
If none of the above helps, I highly suggest that you attempt to borrow or purchase an extra sound card. If you do so through a place like Newegg and it turns out that it doesn't fix the problem, you should be able to return the product.
Keep in mind that none of this is exact, you could disable all programs and still hear the sound and it might be a Windows process causing the problem (very unlikely). Or, you could switch to a different sound card and still hear the sound and it might be caused by the drivers for the other card (unlikely).
Good Sound Cards:
HT | OMEGA Series (Striker, Claro)
Sound Blaster X-FI
M-AUDIO
Newegg.com Sound Cards
If you're looking for a low budget sound card to replace yours, your best bet is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102003
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
I will try these today. But I should add that it's not only my left speakers which give white noise, but all of them
4096MB RAM
ATI Radeon HD 4870
Silencer 750 Quad
2 Fans
Welcome to Seven Forums. I read you hear White Noise and I think of this YouTube - White Noise Trailer Hopefully the above will be of some help. Fabe
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
I don't have any sound at all after I re-installed my drivers
4096MB RAM
ATI Radeon HD 4870
Silencer 750 Quad
2 Fans
If you're getting noise on all the speakers then it's less clear than before. When you get noise on one side it's usually hardware and not drivers (drivers are more likely to effect everything).
Not having any sound after a driver update is odd. Make sure you installed the correct drivers and did a reboot after you installed them.
W7 Ult. x64 | OS X
{Internal}
{Externals}
Magsafe
2 x 6000 RPM Fans
I've had this no sound-problem before, and somehow I fixed it, but I kind of forgot how I did that. See, the problem is that my system doesn't detect any plugged in speakers, which they are. Then it automatically set my default playback device to 'Realtek Digital Output', I believe I had/have to change some settings to get my sound back, I just need to find them settings
4096MB RAM
ATI Radeon HD 4870
Silencer 750 Quad
2 Fans
I have the same problem! i've tried loose conections, driver sweepers, other speakers, i even went so far as to format my hard drive and re-install windows, but to no avail. does this mean i need to purchase a sound card? i'm using integrated audio.
windows 7 64bit
windows 7 64bit
