X-FI Fata1y Pro problems please help!
Knivestheacegun
10:28 PM
Hello,
First of all forgive me if this is an issue already tackled here on the forums. I have such a busy schedule, i don't have time to search though.I've tried searching other places but my problem seems unique.
what you need to know About my setup:
OS-Windows 7 HP 64-bit
Sound card-Creative Sound Blaster x-fi Fatal1y pro {PCI express}
\ / Connected with Optical
5.1 Home theater receiver DTS/DD
My problem-
When I do anything with sound(Play a game with Dolby digital live, Listen to an MP3 file, Watch a MP4 video, watch a youtube video)on occasion, my receiver will try to switch to linear PCM and the sound will cut out for half a second and come back in with DD or DTS (whatever encoder I select in Creative control panel).I did not have this problem at all with windows XP, Everything worked perfectly. It seems to happen most on my MP4 videos I record with my digital camera.I've contacted creative. I uninstalled all packaged software along with drivers and downloaded all windows 7 crap for this card. It still does it.
I have two playback devices-
Speakers-Default device
Spdif out
(my on board audio is disabled in bios)
If I switch default to spdif-No sound will come out and My Receiver will not get any encoder signal.
My thoughts-
1. It has something to do with sampling rates not being set properly? i've used the test and it will do 44.1 khz to 48 khz both up to 24bits.or maybe something about exclusive control?
2.Its having trouble with stereo or mono sound being encoded to Dolby digital/DTS?
I've tried everything I can think of.
Any suggestions would be greatly appreicated.
Thanks in advance.
Windows 7 Home premiumPentium D 3.2 + 3.53GBNVIDIA 9600 GSO 768MB DDR3
Pentium D 3.2 + 3.5
Asus PN5-D
3GB
Sound Blaster X-FI Fata1y PRO
32" LCD
500 SATA
Antec 650w
Powmax
Lots
Can you use Stereo sound instead of Dolby/DTS? I'd suggest that you go through the running startup programs & processes in msconfig and disable half of them. Start the computer up and if the problem still exists, try disabling the other half. My thinking being that a program interaction is causing this.
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
Now no sound through spdif
Now i cannot get any sound through OPTICAL at all.
I uninstalled All drivers using Driver sweeper and tried all new drivers.Nothing.
I can get sound through analog speakers with new driver though.but no OPTICAL.
I can get sound and linear PCM to display through my onboard Realtek 883 using COAX out. It also has OPTICAL and nothing comes up when its plugged in.
I Downloaded AC3 filter. Under SPDIF status it says NO status. ANd when i run the test it says no support for any sample rate.
I cannot figure this out.
Some windows 7 update that screwed this up since my clean install because even the original drivers(pre windows7) worked then?
Maybe the OPTICAL cable is broken?
Linear PCM works and the DVD player still does Dolby digital on same connector so I don;t think my Reciever/AMP is broken?
please help.
Pentium D 3.2 + 3.5
Asus PN5-D
3GB
32" LCD
500 SATA
Antec 650w
Powmax
Lots
