No audio devices are installed. Please help.
JoshDavis
5:00 AM
Hi
I recently upgraded from XP to 7 and have been stumped by a problem for over a week now that I can't seem to find in any other forums.
I have a Gigabyte GA-965P-DS3P motherboard with RealTek High Definition onboard sound (I'm pretty sure, could someone confirm this?)
RealTek High Definition Audio appears in device manager but in the Sound window of Control panel it says there are "No audio devices installed".
I have the most up to date driver for the RealTek onboard sound from the thread on this website. (Driver version - 6.0.1.6083), yet it still doesn't show as an audio device?
When i try to let windows update them automatically they say i have the most up to date drivers?
Under properties for Realtek HD Audio i have this error "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39).
Any help would be greatly appreciated.
Cheers,
Josh
Windows 7 32 bitIntel E660 2.4Ghz Dual Core2GB G.Skill DDR2XFX Nvidia GTS 250 1Gb DDR3
Windows 7 32 bit
2GB G.Skill DDR2
Sound Blaster Audigy
AOC 197V
2 x 250GB Seagate Barracuda
Raidmax 500W
Zalman CPU Fan
In your BIOS, do you have an option for Azalia codec? is it enabled?
Also, did you know you have to install the Drivers twice? The first time removes the old drivers, the second time installs the new driver.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
BIOS
Hi Ap,
In my BIOS i have two options for Azalia Codecs, auto and disabled. I have it on Auto. I have installed the driver for the onboard sound a couple of times to make sure the old driver has been removed.
When i turn on/restart my computer a Windows Update "Playing Audio" troubleshooter opens and says that re-intalling the driver might work and do I want to apply this fix? It tries to install an update for my Realtek High Definition Audio but fails. Same for the Microsoft Trusted Audio Drivers.
"Problems found
Realtek High Definition Audio has a driver problem Not fixed X"
In my device manager it shows Microsoft Trusted Audio Drivers and Realtek High Definition Audio under Sound, Video and Game Controllers but they both have the yellow triangle with exclamation mark in the middle.
Thanks for your reply.
Any ideas what could be going wrong?
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Errors
Maybe this helps
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
I just looked that motherboard up on the Gigabyte website and it says it uses Intel High Definition audio... might want to try getting the driver from the manufacturer's site.
windows 7 Ultimate x64Core i7 3770K8 GB Corsair Vengeance DDR3Asus Nvidia GTX 770
Core i7 3770K
Asus Sabertooth Z77
Asus Nvidia GTX 770
Asus Xonar Essence STX
Asus VG248QE
1920x1200 @ 60 Hz
Western DIgital Caviar Black 1 GB
Corsair Force GT 240 GB
Corsair HX-1000
Corsair Air 540
Corsair H100i
Microsoft Sidewinder x4
Intellimouse Explorer 3.0
Cable
Intel Driver for Audio
On the Gigabyte website, under audio drivers for the GA-965P-DS3P is says the most recent update for an audio codec is
"Realtek Function driver for Realtek Azalia audio chip (Including Microsoft UAA Driver in English edition) Version:R2.45 39.36 MB"
This is from the manufacturer website?
It doesn't mention anything about Intel in the driver updates even though in the product description it says it uses Intel High Definition Audio????
I have downloaded the most up to date version of this from a thread in these forums. Version R 2.46. In my BIOS i have an option for Azalia Codec too? Which i have enabled.
I am seriously confused? Do i have Realtek or Intel? And what is the driver i need for Intel if so because i can't seem to find anything on the website.
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Hi Ap,
"Problems found
Yep, "Auto" is the correct selection in the BIOS.
This is what Gigabyte lists.
GA-965P-DS3P (rev. 3.3) - GIGABYTE - Support&Download - Motherboard - Driver
It's version 2.45 of the Realtek driver.
Do you have the Audigy out of the machine and removed any and all related creative drivers? (i looked at your spec)
i would use the Control Panel applet to remove all audio related drivers, first uninstalling them in Device manager then try the Gigabyte Realtek driver.
We've seen other problems here but not the audio device being recognized... not unless you have other cards or devices that are causing a direct IRQ or address conflict.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Yeah the Audigy is gone. I gave up on trying to get that working and would prefer onboard to nothing at all.
I have completely uninstalled all Creative drivers and Realtek Drivers. Device manager now looks like this.
Downloading R2.45 from Gigabyte site now.
I have seen a few different types of methods for installing the driver. Should i run the setup.exe or is there a way i should manually install?
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Ran the setup.exe and restarted.
Installed but still no audio devices installed?
Any ideas?
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Any ideas?
You did an upgrade over the top of XP?
Did HD audio work under XP?
The only think I can come up with is some conflict with left over settings or files.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Reinstall
Just reinstalled 7 without the SB Audigy. Started up and BING. HD Audio Device running fine in Device Manager and an HD Audio Device in Control Panel > Sound.
Sweet.
I'm a bit hesitant to try setting up the Audigy now because I'm so stoked right now to have sound that I'd hate to mess it up again so soon.
But if I was to attempt to get it working how should I go about it?
Disable Azalia Codecs, put the Audigy back in, download this driver:
Creative Sound Blaster audio driver 1.04.0090
Does that sound right?
I have the Audigy SE with the model number SB0570.
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Sweet.
Aha... so it was the Audigy drivers.
The 1.04.0090 driver looks like the right one, here's fair warning... The Audigy cards (I have one too) sound like crap under Win-7. The Realtek actually sounds better.
You can try it, but besides disabling the Azaila codec I'd also uninstall the Realtek drivers.
There are a couple of third party SB/Audigy solutions that sound pretty good, I've always been partial to the KX drivers, they sound great.
Official kX Project Site -- News
Keep us posted when you reinstall Windows again! ;)
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Thanks for all your help.
In that case I might just stick with the onboard. Sounds just as good to me.
Cheers for all your help. Trying everything that you suggested eventually led to working out what the problem was.
Thanks very much.
Windows 7 32 bit
2GB G.Skill DDR2
AOC 197V
Raidmax 500W
Zalman CPU Fan
Thanks very much.
Hey, no problem... glad to be of help. Win-7 has been playing bad with audio for quite a few users. The Gigabyte motherboards seem to do pretty well, I had a bit of trouble at the beginning but all is well now. Updating the MB BIOS helped.
best-
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
