audio glitch
  1. Posts : 3
    windows 7
    audio glitch
    Hello , upgraded from vista to windows 7 and happy with it . until now i have audio glitches! I ran the dpc latency checker and one driver is going out of the roof! i tried to disable every possible driver but i cannot find the cause. please help me
  2. Posts : 1,241
    Windows 7 Profesional x86, Mac OS X 10.6 Snow Leopard
    Hi and welcome to the forum .
    A good place to start would be to ensure that all your drivers are up to date and that all your hardware is Windows 7 compatible (which I am sure it is).
    Please could you also fill in your System Specs under User CP and tell us what sound card you are using?
    Oli
  3. Posts : 3
    windows 7
    thanx for your answer, my drivers are all up to date en my hardware is compatible , my soundcard is a conexant high definition smart audio 221. But i don't need it . i use a reloop digital jockey with build in sound card. i run the dpc latency checker with the reloop digital jockey not connected and all not necessary devices unabled. but cannot find the cause of the audio glitch.
  4. Posts : 908
    Windows 7 Home Premium
    This is a Toshiba laptop?
    In device manager try disabling both the Wireless and the Network adapter, then reboot and run the dpc latency checker.
    Ap
  5. Posts : 3
    windows 7
    yes it is an toshiba laptop satellita p 300, i disabled almost everything (also wireless and internet adapter) but still no luck. It is strange though that all latency is verly low (green bars) but every 4 , 5 minutes something causes a huge red bar?
  6. Posts : 4
    Windows7 Ultimate 32bit
    Hello Guys... have u noticed that sound glitch when u surfing web!!!! ... most of the time.. and 100% it not hardware issue.. because the same hardware works great in vista... I hope SP1 would solve it...
