Problem with Realtek AC97
  1. Posts : 1
    Back when I was just using Windows Vista, my computer recognized my sound card as Realtek AC97, which is what's built into my motherboard (ASUS M3A79-T Deluxe). However, when I started using Windows 7, all that Windows would show for my sound card is "High Definition Audio Device" for some reason.
    I've downloaded and attempted to install both files mentioned for Realtek cards, one of which didn't seem to do anything, the other kept giving me problems due to the driver not being signed by Microsoft, over and over, despite how many times I clicked install anyway.
    I've been ignoring the problem up until now, but it's giving me problems with my front mic jack, which I've not had any reason to use until recently. Going to the recording devices page will show the rear jack working as normal, but the front panel is "currently unavailable" even though it to is shown as working normally.
    I hate the thought of registering on a forum for the sake of asking a question, that may have an answer that I haven't found, but this is kind of annoying me and I'd like it to be fixed if possible.
    Thanks in advance.
  2. Posts : 1,117
    Do you have the front panel HD Audio connector connected to the motherboard or the AC97 connected? Have you tried swapping connectors?
  3. Posts : 592
    WIN7 Ultimate 64bit
    Thanks in advance.
    Just skimmed a review for your M/board and you have an 8 channel HD (High Definition) sound chipset built in the motherboard!
    Did you connect the wrong front connector on your case lead?
    There are usually two plugs/connectors HD and AC97 (for really old motherboards such as socket 7)
    As mpcrsc562 clocked above!
  4. Posts : 908
    Windows 7 Home Premium
    Thanks in advance.
    I guess it might help to know what the problem is.
    Not working at all?
    I would suggest going to the Realtek site and d'loading the latest 2.47 driver.
    It's a two step install, the first install actually deletes the old drivers, the second try installs the new drivers.
    You might try right clicking on the Microsoft speaker icon in the task bar, you'll find a lot of
    of options available.
    http://www.realtek.com.tw/downloads/...&getdown=false
    Get either the zipped or exe.
    Ap
