Realtek HD Audio problem
danielprescott
5:54 AM
Hi, I'm having a few problems with certain sound drivers in windows 7. I recently done a clean install of Windows 7 and my sound is quite crackly.
In Vista everything was fine and I had the Realtek HD audio software installed.
Now whenever I try to install the same software it says there is no driver to support or something along those lines.
I'm just a bit confused as to what to do next. Whenever I open the device manager to check the driver it says "High definition audio device" and whenever I try to update the driver it says it's already got the latest driver installed.
Any help would be much appreciated
thanks
Windows 7Intel Pentium Dual-Core 1.73Ghz2GB
Advent
2GB
win 7 ultimate32bit, Win8.1pro wmc 32bitamd phenom x4 9600corsair twinxs 2x2gb2x nvidia 1gb 8500gt
self build
amd phenom x4 9600
asus m2n32-sli deluxe
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
Try to uninstall the drivers, then the device from "Device Manager" (with the uninstall button on the device's properties). Then download the drivers again. Make sure you're getting the right ones. Get the drivers from the OFFICIAL realtek website, others might be fake... After downloading, install, then reboot. If that doesn't work check for any dust around the audiocard on the back of the PC. Crackling may also be caused by wrongly configured audio settings. Preinstalling the driver (just like I told you) will allow you to start afresh and to make up your full audio config all over again. ;)
Windows 7 Home Premium [64-Bit]Intel Core 2 Quad CPU Q8200 @ 2.33 GHz4094 MB DDR2SAPPHIRE Radeon HD 6970 (2 GB VRAM)
Multirama PC Expert [Bulgaria]
GIGABYTE GA-G31M-S2C
4094 MB DDR2
Realtek ALC883 @ Intel 82801GB ICH7 - High Definition Audio
Samsung SyncMaster BX2235 [21.5" LCD with LED Backlight]
Hitachi HDT721075SLA360 - 750 GB
Cooler Master GX750 - 750W
Multirama (Black / 2010 Revision)
Stock + Cooler Master
Logitech G510 (Gaming Keyboard)
Razer Lachesis (4000 DPI, Blue Version)
Vivacom Optical [100 Mbps]
Chrome [Windows]
thanks I'll give that a go. I can't go back to vista drivers because I done a clean install of windows 7. Got rid of windows.old
Advent
2GB
you can download the vista drivers from the realtek website Realtek :)
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
It's pointless using a vista driver when I have windows 7 isn't it? anyhoo. I uninstalled the driver and reinstalled it using the realtek installer. Went fine but the sound was still crackling and the realtek audio software is nowhere to be found. It's just really frustrating. If I try and install it now I get an error saying device driver error oxooooo103
Advent
2GB
The drivers from Realtek for both Vista and W7 (32-bit and 64-bit) are in the same package.
Gigabyte IF233
Avast! 8.0.1497
IE 11
a lot depends on the age of the realtek sound chip ,if its more than 2 yrs old ,you will find an older version of the driver [vista] will work better ;)
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
In the Realtek website when you look for HD audio drivers, at the top it gives you a driver that is supposedly for BOTH Windows Vista and Seven, so this might be some kind of bug in the new version (what's weird is that I myself have a Realtek HD AudioCard and am NOT experiencing any problems with the latest software version). What version of Windows 7 are you running? Is it original software or BitTorrent?
Edit: Yet again - F***! Dwarf and pebbly already covered all that I said XD! I'm getting slow at writing on my keyboard ever since I started using it mostly for gaming... :o
4094 MB DDR2
Chrome [Windows]
it's genuine. The sound seems to crackle whenever I hover the mouse around. Gets particularly crackly whenever I play a high def video. The quality levels are all normal and if I go higher than cd quality it really makes a noise.
Advent
2GB
I got this problem too when i install the new update in realtek the sounds crackle :S help please.
Windows 7Intel I3-6100 3.7GhzCrucial Ballistix Sport 8GBHIS IceQ X Radeon R9 270
Asus H170 Pro Gaming
Samsung SyncMaster SA300 18.5
1366x768
Seagate Barracuda 2000GB
Corsair VS550
Deepcool Dukase V2
Windows Defender
sorted it. I got the last realtek driver before 7 was released. Probably the driver I was running before I upgraded. :)
Advent
2GB
