How to fix 99% of Win 7 audio problems
Alkotashi
8:44 PM
Norway
Some time ago I stumbled over an article about DPC (Deferred Procedure Call) in Windows and the issue of latency problems regarding that process.
Problem:
In essence, DPC relates to a CPU tunnelig process in which all streaming media (audio/video playback/recording etc.) in Windows are subjected to. Transferring data to and from a soundcard requires the device driver to send a DPC request to the CPU. As Windows can't multitask by design, each CPU-Core has only one queue for all hardware. It's a first in first out principle and the timing and flow is subject to whatever is happening in all running tasks, processes and services regarding hardware at the time.
This process is the basic problem for all audio malfunctions, there might ofcourse be other issues but if DPC latency is low and stable the problem is certainly found in either audio software or hardware settings.
How to fix and maintain sound issues:
DPC latency can be monitored in real time with this magnificent tool from Thesycon Systemsoftware. Being German, they also write thorough procedures on how to use it so I'll leave it to them to explain the process of eliminating problems. A more in depth explaination of DPC is also found on the bottom of that link.
In addition to their information - It's important to note that services, scheduled tasks and startup processes also should be checked in addition to drivers while verifying DPC latency. Many 3rd party services (and sometimes Windows services like diagnostics and similar) do heavy communication with hardware. These should be disabled while monitoring DPC latency to see what effect they have on your computer. As for software, all kinds of Media Centers, iTunes, integrated security software etc. usually installs heavy background processes cluttering up the system and should be avoided.
By trial and error over years using Windows based studios and live performance software I've found that every problem, especially on Win 7, have shown up on the DPC latency checker, thus making them easy to eliminate by following the above examples using Thesycon's benchmark.
For all of you with audio problems out there I hope this helps - Good luck!
Regards,
Rainer
Windows 7 Ultimate x64Intel Core i7 96012GB Mushkin DDR3 Triple ChannelZOTAC GeForce GTX 560Ti 1GB PhysX CUDA
Intel Core i7 960
Gigabyte X58A-UD3R r13
M-Audio ProFire 610
Samsung SyncMaster 226BW + Benq FP222Wa
3360x1024
RAID 2x OCZ 120GB SSD S-ATA III (System)
RAID 2x Seagate 1TB S-ATA III (Recording)
1x WD Black Edition 7200 2TB
2x WD Black Edition 7200 1TB (Sample archive)
2x WD Caviar 7200 500GB
1x Cavalry Caum 7200 2TB
Thermaltake Toughpower XT
CoolerMaster Stacker v2.0
Antec KÜHLER H2O 620
Logitech diNivo Laser Desktop
Logitech MX-900
VDSL 40/10
It is a DAW. Mostly.
Hey Rainer, we've been on the DPC tool for a few months now, it's definitely helped quite a few.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
I would guess that this will help a few out there. Good one.
Windows Seven
Windows Seven
Sound blaster
Oh.. well, I'm new here, usually few people know about this but that's great.
Intel Core i7 960
M-Audio ProFire 610
3360x1024
Logitech MX-900
VDSL 40/10
A good read Rainer :)
Steve
Windows 7 Ultimate 64 - OEM Service Pack 1Intel Core i7 930 2.80Ghz Bloomfield Socket L...Patriot Viper 6GB 3x2GB DDR3 PC3-1200C9 1600M...Asus ATI Radeon HD 5770 CuCore 1024MB GDDR5 P...
Over Clockers Ultima Viper 2.80Ghz
Intel Core i7 930 2.80Ghz Bloomfield Socket LGA 1366
Gigabyte GA-X58A-UD3R Intel X58 Socket 1366 DDR3
Patriot Viper 6GB 3x2GB DDR3 PC3-1200C9 1600Mhz Tri Channel
Asus ATI Radeon HD 5770 CuCore 1024MB GDDR5 PCI Express
Realtek ALC889 @ Intel 82801JB ICH10 - High Definition Audio
Samsung SyncMaster 920N 19"
1280*1024
1 x OCZ Vertex2 Series 120GB 2.5" SATA-II SSD
1 x Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
1 x Western Digital Caviar Green 2TB SATA-II 64 MB Cache
Corsair TX 650W ATX SLi
Antec 902 Ultimate Gaming Case Black
Prolimatech Megahalems Rev B CPU Cooler Socket 775/1156/1366
Microsoft Comfort Curve Keyboard
Microsoft Optical USB
ADSL24 FTTC 34.2 Mbps Down 7.1Mbps Up
OcUK 22x DVDSATA ReWriter Black
Akasa AK-FN058 Apache Black Super Silent 120mm Fan
Printer Epson Stylus Photo R300
Scanner Canon Canoscan 8000F
Yes, but you included a lot of good info that wasn't posted before so thanks!
I pasted this from a post I'd made a couple of weeks ago.
http://www.sevenforums.com/attachme...ing-sound-audiodg-exe-problems-dpclatency.jpg
Don't think it can get much better than this.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
