Windows 7: Microphone not working most solutions didn't help.
10 May 2010   #1
Windows 7 Professional
Hello,
I've switch to Windows 7 for like 5-6 months and recently I decided to test out my microphone for Warcraft III. So I plugged it into my microphone jack and decided to try it out via "Sound Recorder." I ran the program and I got the error message
"An audio recording device cannot be found."
So I decided to google around.
Most results said to go to control panel and click "Show disabled devices" Clicked and nothing showed up.
Other results included,
"Update Drivers"
My drivers are up to date. I checked I even downloaded the realtek driver thing and installed it. Still no dice.
I know my microphone works because I just brought it to my school today and it worked fine. I also know my Jack isn't broken due to the fact that 6 months ago I had Windows XP and I used it often.
TL;DR: Mic cant be detected, tried solutions, didn't work.
Help.
12 May 2010   #2
W7 Ult. x64 | OS X
Just an FYI...
Your jack may have worked 6 months ago but it may not be working now. If your computer isn't even detecting the microphone port when unused it may be malfunctioning.
13 May 2010   #3
That is a variable yes but can there be other problems?
14 May 2010   #4
windows seven
It happened to me as well BUT ultimately I found that mic jacks are faulty...I saw that the same mic was working on my laptop and not on my desktop..Go to configure the mic and then slightly slid the mic jack inside and out and you may find that it is working OR bring some other mic and see.
14 May 2010   #5
Hello Jimmeh,
If your audio output is for example 5.1 or 7.1, the sound system changes all jacks to audio outputs.
Sometimes Windows 7 changes the order of output jacks, try another holes too.
Hope this can help
15 May 2010   #6
@Apple: I tried other MICs and it didn't work. I've tried fidgeting with the mic in the jack but no dice.
@Mace: I only have 2 holes, Headphone Jack and Mic Jack.
17 May 2010   #7
I'm pretty sure that this has something to do with settings. Jacks just doesn't break like that.
Check out the "Recording Device" settings. It must have something to do with it. Windows 7 is pretty complicated when we're talking about sound, specially with on-board sound card
18 May 2010   #8
W7
I have a similar problem in that my mic works intermittently, requiring me to sometimes 'unmute' it. I'm not in front of my Windows 7 PC at the moment, but I think it's in Sound > Mircophone > Recording tab > Properties > Levels tab. If the speaker icon has a red cicrcle on it, then the mic is muted. Click the speaker icon to 'unmute'/enable it.
This post shows a similar solution Microphone
03 Jun 2010   #9
windows seven
Hi once again..I found that my mic was also not working properly or intermittently and the problem was the driver. I installed an old driver which I found somewhere and now it is working like a charm.
Similar help and support threads for2: Microphone not working most solutions didn't help.
Microphone not Working Sound & Audio
Solved Speaker working but builtin microphone not working. Sound & Audio
Solved BOOTMGR is missing and no solutions working. General Discussion
Sleep/Hibernate not working, update didn't fix Performance & Maintenance
Built-in Webcam Microphone and Microphone Line-in Not Working Hardware & Devices
Microphone is too quiet - tried many solutions. Sound & Audio
Not sleeping (general solutions didn't work) Performance & Maintenance
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
