Windows 7: microphone problem
21 May 2010   #1
microphone problem
i had a hp vista in that hp it has a built in microphone that it worked great.
i got windows 7 as an update to my computer.
when i tired to go on skype to use my microphone it didn't work something about it
not detecting the sound card.
the microphone is built inside the laptop
21 May 2010   #2
PooMan UK
Windows 7 Ultimate 64bit
Hiya pal and welcome to the 7 forums.
It would really help if you could fill in your system specs. Just makes it easier and quicker to help you with your problem ...
 microphone problem
Search this Thread:
Advanced Search
Microphone problem
Hi everyone, I have a built in microphone in my laptop but when i call someone through messenger the detector is not affected by voice while i am near to it & the person talking to me says that voice is heard as if i am 5 meters of laptop. where i dont have sound card driver which is conexant...
Microphone Problem??
Ok basically my TravelMate 5520 Laptop has a built in microphone but it doesn't seem to be working. Below is the screen show of "Sound" in the control panel. The green bar seems to be constantly high even when there is no sound. I have tried both of the microphones shown below even though I only...
Hardware & Devices
Microphone problem
Hello , I'm simasce and this is my first post ------------------------------------------------------------------------------------------------ 1 month ago I've got a big and annoying microphone problem I've started a VoIP game and when i talk users hear a weird sound like scratches and when...
Problem with usb microphone
its part of my webcam an my webcam works perfectly fine but for some reason my mic will not show up under the recording tab it only shows sigmatel audio for the recording device is the problem that my usb doesnt support audio?
Hardware & Devices
Problem with my microphone
Hi everyone, I worked for a long time with Windows XP. I used this computer for podcast recording: - Windows XP - Input: Stereo-Mix Now, I have a new computer, Windows 7 Ultimate 32bit. When I plug my microphone in my computer and start Audacity, the sound is very bad. It's the same...
Microphone problem
Ok, so I have tried and tried, I've been to countless forums and browsed countless threads trying to figure out how to get my microphone to work. The other day I upgraded my OS to Windows 7 64-bit, everything was working fine before hand. I upgraded the drivers on my on board sound card (Sound...
