Windows 7: volume controls itself. help please!
11 Jun 2010   #11
matthes2
MS Windows 7 Home Premium 64-bit
Im having the same problem, except for the browser being stuck in "back" mode. Sound fluctuates from violently loud to almost-nothing quiet. Very annoying since I play many games and music with sound on.
I think the sound fluctuations have something to do with my 5.1 surround sound system I have. Right now only two speakers and the bass work, even though in the testing all 5 speakers make the proper sound. I read somewhere else that the sound fluctuations are related to the sound trying to play in all 5 but unable to.
If anybody has a solution to this problem, please help! Its been a bother for over a year now.
Also, the problem was present when I was using my old system, a Dell Dimension 4700 Desktop from 2005. The problem has seemed to carry over to my whole new system (speakers, monitor, keyboard, and mouse are the only things from the previous system).
Here are the specs of my new system, hopefully somebody can point out a flaw somewhere:
Operating System
Intel Core i7 860 @ 2.80GHz 45 C
Lynnfield 45nm Technology
RAM
4.0GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
ASUSTeK Computer INC. P7P55D-E (LGA1156)
Graphics
VA1930wm @ 1440x900
ATI Radeon HD 5600 Series
313GB Western Digital WDC WD3200AAKS-00M9A0 ATA Device (IDE) 40 C
Optical Drives
HL-DT-ST DVDRAM GH22NS40 ATA Device
Audio
ATI High Definition Audio Device
11 Jun 2010   #12
Aphelion
Quote   Quote: Originally Posted by adamlh View Post
okay so i finally gave in, wiped my computer, reformatted it, installed a clean version of windows 7 with all new drivers and updates. it took less than 12 hours for the problem to return, despite not loading anything onto the computer. so now im at a complete loss. what the hell can be causing it? already
I once worked on a laptop that had issues with random windows opening, menus dropping down and other odd interface problems.
Turned out it was heat related, specifically, the processor and/or possibly the mainboard chipset. I was never sure which one because they were both cooled by the same fan system. The fan was multispeed but the only speed that worked was low, as soon as the machine generated enough heat for the fan to notch up, it would turn off!
Anyway, temperature might be something to check, perhaps it's heat related.
The only other thing I can think of that would mess with the volume control is a background app like Real Audio or Possibly Winamp.
After a reboot I would use task manager to shut down all but the basic processes Windows needs to operate... especially any nVidia processes -and- nvidia services.
Ap
02 Apr 2012   #13
sforsythe
W7 64 bit
I have the same Gateway system and the same problem exactly. More than just the volume control and browser, but all programs that exhibit the problem "stutter" as if someone is banging on a key. I did find that if I put the PC to sleep and wake it up, the problem is gone for a while.
23 May 2013   #14
xantl
Windows 7 Enterprise 64 bit
Are you still there?
Is this problem solved? Didn't sound like it.
I have this problem, but I traced it to particular applications. If I restart the computer it goes away until I start one of those applications. I think it's an application-based problem.
You response?
29 Dec 2014   #15
infotech656
Windows7 Home 64bit
Volume Control moves on its own
Had the same problem and tried everything I thought !!
Volume control moving to full volume on its own.
I discovered my MOUSE WHEEL had stuck Pushed it across and heard it click
The computer volume control now only increases/decreases if I move it.
Hope this helps ( Try a new mouse )
keyboard volume controls wont work
after clean install my microsoft curve 2000 keyboard volume -/+ /mute wont work ive installed the intellitype software and reinstalled realtek hd sound drivers and there is nothing it worked previously b4 clean install
Hardware & Devices
Windows system volume only controls left channel
I am using a Xonar ST on Win 7 64bit......All of a sudden I noticed I was only getting sound on the right side. I reseated the card, reseated all of the connections, and changed the power connection from the PSU, and made sure on board audio was disabled. I went into the control panel and...
No Level Indicator When Using Keyboard Audio Volume Controls
Guess what guys ? I have a new problem ! Imagine that.I've googled for answers and closest I came was the Dell quickset app.But,after downloading 3 versions (the last one actually installed) my problem is not solved.It's a small issue really.But,annoying.... The problem is when I use the...
Volume controls on K800 Keyboard do not work with Headphones
Morning, Bit of a weird one here...within the last week - I installed a fresh copy of Win 7 x64 SP1 on a new office workstation. I am using the Logitech K800 keyboard and J.River Media Center for media playback. NOTE: I am using the Gigabyte EP45-UD3R motherboard and it's onboard Realtek...
Volume Controls in full screen applications
Hi i am able to use my logitech internet navigator keyboard to adjust the volume on the desk top or really any thing thats not full screen but the second that i switch to full screen such as on youtube or a video game i am unable to adjust the volume until i alt tab out to do so if any one knows...
Volume Control Panal..controls itself
My volume control panal..taskbar..wont let me set the volume any longer. It slowly raises itself from the lowest setting to the highest. Any ideas why this is happening and how i can fix it?...I am not using a sound card. On board only. thanks Intel Q9550 Asus P5EVM-HDMI EVGA 8800GT 8 gb...
