Streaming Audio/Stero Mix and Mic at the same time HELP!
Lavitz
4:22 AM
Hey guys, i need some help streaming audio on game broadcasting show I do. But I am having a difficult time getting it to work properly. I don't really want to purchase any new hardware want to try to use what I have.
My desktop is what I am streaming on. Pc Gaming W/ Lavitz on Justin.tv
I can stream game audio fine through stero mix but I can't talk on my mic .. but I can speak into my and have have go through steromix but thats an issue for me because when I game I use ventrilo and when press the talk button people HEAR GAME and when they talk it loops back to them.
I can't enable steromix and mic at the sametime.. I just doesn't work. I have soundmax audio driver.6.10.2 thats the driver I have at this time.
I have a super old audiocard I can install into my pc. Its an Soundblaster Live Model:Ct4780. But there no windows 7 drivers for it.. So thats not working if that work it could use separate sound card to mic audio. If you guys can help install this I think my problem could be solved.
Anyways, I have done much as I could no luck. Also I have analog mic (jack in)Not a usb mic.
What I have:
Soundblaster Live Ct4780
ADI AD2000B
razer carcharias
Windows 7Intel Core i76gb ddr 3 g.skillgtx 260 evga
Intel Core i7
Asus p6t deluxe v2
6gb ddr 3 g.skill
gtx 260 evga
none-integrated
19'' Asus 1680 x 1050
Western Digital Black 512gb
Corsair Modular 750
Haf 922
Bump before this goes 2nd page. I really need problem abv re-solved.
Intel Core i7
Asus p6t deluxe v2
6gb ddr 3 g.skill
gtx 260 evga
none-integrated
Corsair Modular 750
Haf 922
last bump.
Intel Core i7
Asus p6t deluxe v2
6gb ddr 3 g.skill
gtx 260 evga
none-integrated
Corsair Modular 750
Haf 922
I have the same issue. Any sound that is coming out also gets transmitted. >.<
Windows 7 Pro x64Intel Xeon e3110 (e8400) @ 4.0ghz8GB DDR2-800 @ 890mhzXFX Radeon 4890
Me
Windows 7 Pro x64
Gigabyte EP45-UD3R
XFX Radeon 4890
X-Fi Xtreme Gamer
Asus VH242H
3x WD 320GB
Raid 0 and storage
PC Power and Cooling 750watt
Lian-Li Kc7-b
Tuniq Tower 120
This is something I'm not familiar with but at least it will help keep your question bumped to the top.
When you right click the MS speaker icon in the task bar and select recording devices you have (or at least had) "Stereo Mix" selected as default, correct?
When you select the Default Device... and then the "Listen" tab, explain how you have this set up.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
