does not detect sound card
thewink
2:43 AM
i got the windows 7 RC 32bit yesterday and it doesnt seem to detect my sound card, i have tried installing the driver but have had no luck with that
my sound card is Hercules Gamesurround Fortissimo III 7.1
any ideas? i have googled for a solution but havent found anything
windows 7 dual-booted with xp pro sp3
Hello thewink,
This is always going to be a problem with older hardware as the manufacturers just don't see the point of releasing new drivers :( You might be better off getting a new card.
Try this link; http://www.xpvistasite.com/gamesurround_fortissimo_iii_7.1_3732.htm
Pooch
Windows 7 Ultimate x64Intel Core i7-2600K16 GB G Skill F3-10666 CL9D-4GBRLATI Radeon HD 6870
Something I threw together
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
thanks for the reply pooch, never thought that would be a problem since i have never had a problem with that sound hard
im gonna try to talk my parents into buying me a newer sound card if the driver from xpvistasite wont work
If you haven't already solved this problem, I had a similar thing with my Gamesurround Fortissimo II card. I've just got it working by first installing the vista/xp drivers from the hercules website. Then I went in to device manager (right click computer->manage) and found the sound card (it may have been called unknown device), right clicked on that and chose update drivers and then pointed the wizard to the folder :
C:\Program Files\Hercules\Audio\Crystal Sound cards
It successfully installed the drivers and now I have sound.
thankyouthankyouthankyou numb
i'll try that right away
ok i think the drivers installed properly now, thanks ^^
Buy a HT claro plus
7600x64 RTMIntel® Q6700, 2.66 GHz stock clock (upgraded)4g (upgraded)Sapphire Radeon Toxic HD 3870 512MB GDDR4 (up...
Dell E520
7600x64 RTM
4g (upgraded)
Sapphire Radeon Toxic HD 3870 512MB GDDR4 (upgraded)
HT Omega Claro Plus (upgraded)
22' , 40"
1050, 1080p
1.5tb (upgraded)
Zalman 600w (upgraded)
stock Dell
dell
dell
100m Fiber optical
Bought the Dell secondhand for cheap and upgraded cpu, vga, ram, soundcard, psu and HDD's.
THANK YOU! :thumbsup:
Windows 7 Enterprise x64
