Windows 7: sound card issue
29 May 2010   #1
firozraj
sound card issue
can anyone tell me ?why speaker is not working ?meanwhile microphone is working .
i am using hp laptop.kindly let me know the idea.any help would be highly appreciated.
29 May 2010   #2
kucing13
maybe filling your system specs and telling us you laptop model can help us to help you. I believe this a problem with sound driver.
30 May 2010   #3
firozraj
Kindly find the attachment for sound card hardware id .and let me know the idea.
30 May 2010   #4
Capt.Jack Sparrow
Quote   Quote: Originally Posted by firozraj View Post
Hello !! Welcome to SF !!
What laptop are you using ?? What is the model of it ??
Edit: I found two Audio Drivers that might work for you
Conexant HD-Audio SmartAudio 221 Driver Compaq Presario V3713TU Notebook PC - HP Customer Care (Singapore - English)
Conexant Audio Driver (32-bit) Compaq Presario C300EA Notebook PC - HP technical support (United Kingdom - English)
Captain
30 May 2010   #5
kucing13
can you provide us with your laptop model ?
30 May 2010   #6
firozraj
hp pavilion dv6000.
our sound card hardware id is :
HDAUDIO\FUNC_01&VEN_14F1&DEV_5045&SUBSYS_103C30BB&REV_1001
30 May 2010   #7
kucing13
try downloading the sound driver from HERE. It says vista,but it maybe works with seven too
edit: install the driver in compatibility mode. right click the installer>properties>compatibility mode>vista.
02 Jun 2010   #8
kucing13
for your toshiba. you can download your driver from here and here
In any case if the drivers for windows seven is not available. you can try installing it in vista compatibility
03 Jun 2010   #9
firozraj
i have downloded and tried to install but fail.This is also not working.i am using u300 model of toshiba laptop.and microprocessor is x86.kindly let me know the idea.
 sound card issue
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Speaker/sound card Configuration Issue
Hi guys, i'm new to this kind of things, had a question which probably many of you already have done: I bought a new pc, Dell, with a Creative Soundblaster X-Fi Xtreme Audio sound card, and a Creative T6160 speaker set. The speakers should be a 5.1 surround system (and in facts i have 5 speakers +...
Creative Sound card driver issue
Hello, I have been trying to get my sound card (Creative X-FI SB0460) to work under windows 7 x64, i have followed both a standard method of installation and the "Have disk" installation both failed, the "have disk" method reports it found driver but encountered an error then, fails with a "code...
USB SOUND CARD ISSUE
i just purchased this usb 3d sound card and to my suprise it detects as plug and play on windows 7 without any driver disc... the shopkeeper states its windows 7 compatible.. but somehow on the box it isnt mentioned...:( has anyone tried this device.. ::COMODOW::
Sound card issue
Hi, i recently installed windows 7 ultimate 32bit on my laptop and i love it to bits, but theres just one fallback thats making me want to change back to XP, and that is the sound problem, what the problem is that, when im playing counter Strike 1.6 online, and a grenade goes of, or lots of gun...
Gaming
Sound card driver issue?
After upgrading to 7 I have been experiencing some random difficulties with my sound system. When going to my sound card properties, I notice that there is a generic name to the device, "High-Definition Audio Device". Before I upgraded (when I was on Vista) I'm sure that it said Realtek-something...
Drivers
