No Sound from HDAD
I opted to use the onboard HDAD,but, ther's no sound.
Any suggestions would be appreciated.
You haven't installed the sound drivers yet, it is running on whatever default driver Windows installs. According to the specs for your motherboard you need the Realtek driver,
Latest Realtek HD Audio Driver Version
Get it from here instead,
Realtek HD Audio 2.48 Driver download from Guru3D.com
be a lot faster than getting it from Realtek's dial-up server anyway.
Is it still showing as a HDAD or is it now showing as Realtek HD? Also is the audio on your video card showing as one of the audio devices (should show as ATI High Definition Audio Device or ATI HDMI Audio Device)?
Set it to speakers as the default device instead of digital output.
Make sure that it is also set to speakers/analogue in the Realtek control panel. Also double check that your speakers are connected to the correct jacks on the back of the computer.
