Please help me set up SPDIF
Core7
12:11 PM
South Africa
I bought a HDMI screen with built in speakers but the sound doesn't work and I was told I must plug in the wire on my graphics card and then plug that into spdif on my mother board I did it but there is still no sound what must I still do. He said I must enable it in the BIOS but where is that?
Window 7 Ultimate 32bitIntel core 2 duo @ 2.40 GhzHynix 2X1GBThe Club 3D GTS250 256bit
Gigabyte
Gigabyte
Hynix 2X1GB
laptech
Acer
1440X900
Seagate 350gig
Seagate 250gig
Coolermaster GX 650
Acer
2 80mm fans
Acer
54kb/s
Are you using the onboard sound or a sound card? Do you have it set to use SPDIF as the default audio device? How are you connecting to the monitor (DVI-HDMI cable, DVI-HDI adapter with a HDMI cable)?
What you have listed in your specs doesn't make much sense. Would also help if you listed the model number of the motherboard.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
okay I do not use a sound card I use onboard and I have the monitor connected with a HDMI cable, and the motherboard is GA-G31M-ES2L/GA-G31M-ES2C. and I have set the spdif as default adio device and I can see the bars moving up and down as the sound goes but the sound doesn't come out the speakers, so what could the problem then be?
Gigabyte
Gigabyte
Hynix 2X1GB
laptech
Acer
1440X900
Seagate 350gig
Seagate 250gig
Coolermaster GX 650
Acer
2 80mm fans
Acer
54kb/s
You may have the connector on the motherboard reversed, try flipping it around (pin 1-2 to pin 2-1).
Also is it set to SPDIF passthrough in the Realtek control panel?
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I have done it as the manual said pin 1 is red wire and pin 3 is GND I tried it that way and I tried it pin 1-2, but still no sound :cry:
Gigabyte
Gigabyte
Hynix 2X1GB
laptech
Acer
1440X900
Seagate 350gig
Seagate 250gig
Coolermaster GX 650
Acer
2 80mm fans
Acer
54kb/s
