Microphone will not work after installation
hicisred
3:12 AM
Hey, I upgraded from Windows XP 32-bit to Windows 7 64-bit about 5 months ago. Well, right after I upgraded my headset microphone and audio would not work. I just forgot about it because my gaming declined because of school. Well, now I have come back and I still can't get my mic to work.
And no, my microphone is not muted neither on my computer nor on the microphone itself.
My headset utilizes the traditional speaker and microphone jacks in the computer instead of USB. I use the front panel of my computer for this. I changed the front panel for both to the default sound and mic - got my headphones to work fine with this. Well, my microphone won't work however. The default Windows "Sound Recorder" will not recognize my mic nor will Ventrilo. If I use Vent, they can hear the sounds on my comp that I hear when I press my MIC option--so it is playing back my headset sounds to them (not sure how important this is). Anyway, my mic settings are:
Default Playback Device
Microphone 100, Microphone Boost 100
I'd appreciate any help, thanks a lot.
Have you tried re-installing the driver?
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
How would I go about doing that? Sorry, I don't see it in the immediate options..
In your previous post you said....
The Microphone is an input... so shouldn't you have the "Default Input" device set to Mic and the default playback device speaker or headphones?
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Ap
Ah, just let me clarify...
Under "Recording Devices", I select my Mic and go to Properties > Listen > "Playback Through This Device":
Here I can choose from Default Playback Device, Headphones, Digital Audio (S/PDIF)
The one selected was Default Playback Device. I tried setting the Playback Device to Headphones but that didn't seem to help anything so I switched it back (before I posted on these forums); should I go back to headphones? I'll do that. Still doesn't work, however.
