Windows 7 Forums Search
Windows 7 - Extremely low volume on headphones but high volume on speakers
06-01-2010   #1
MS Windows 7 Ultimate 64-bit
y0 I got this other problem i really hate. The most. Please jonathan_king, zigzag reply please. I beg you, i got this problem that i plug in my headphones and its extremely low volume. It use to work fine, but now nope. I tried the jacks on the front, back and my monitor. Please help me.
06-01-2010   #2
Windows 7 Professional x64
Just so you know, Ken and I aren't the only members of this site. We have 200+ active, knowledgeable members, many of which I'm sure can figure out your problem. Ken and I just roam the Crashes section.
Have you tried a different set of headphones? Have you tried those headphones in another machine?
06-01-2010   #3
try Jon suggestion to see if the problems come from the headphone itself and if you have volume control on your headphone. try maxed it up.
You're using realtek. Go to realtek control panel, speakers tab, note upper right corner link for advanced settings, and try disabling front jack detection.
Feel free to ask
06-05-2010   #4
Alright i think its the headphones that are broken, i tried a different pair and they work fine. I tried the broken ones on the other computer and they still have extremely low volume.
06-06-2010   #5
actually when you're facing some hardware failure like monitor,headphone,etc. It's preferable for you to test it out on the computer to detect either the issues come from the hardware itself or from within you computer. nevertheless, glad you solved your problem .cheers
 Extremely low volume on headphones but high volume on speakers problems?
Similar Threads for: Extremely low volume on headphones but high volume on speakers
How To Let The Volume Change When Plugging In Headphones? Sound & Audio
Low volume when using headphones Sound & Audio
Low sound volume Playback through Headphones Sound & Audio
Extremely low volume in headphones/speakers Sound & Audio
Volume jumps when plugging in headphones Sound & Audio
